Blake, what side are you calling number one? If the L/H [flywheel side] then you might have a problem.. Usually at idle the flywheel side is the one that runs a little hotter due to it firing first & then the R/H side coasts through the firing as the injector sprays.. ~I guess I wouldn't worry too much about it until you get some water in it & put it to work for a while.. You might just have to give it a workout to get both sides to pull evenly... ~Have you used a strong light & mirror & checked the pumps for even movement [& even rack settings] at all throttle [rack] settings? The marks are down under the pumps & real hard to see if you wear glasses.. ~If you want to run some tests you probably should give it a cranking compression test [you will have to make or borrow a compression gage to fit the injector holes].. ~Then pull both injectors & turn them around so they point forward [don't worry about hooking up the bleed-off lines], then crank the engine & watch the injector spray pattern & quantity.. You can point the injectors into [same size] small bottles & give it a good cranking & look for even quantities of fuel in each bottle [that will give you an idea of the pump evenness & adjustment compared to the other side].. CAUTION: don�t use your hand to check the spray pattern as those high pressure injectors can inject the fuel right through your skin].. ~It probably wouldn�t hurt to check the compression release adjustment then check the valve lash.. It�s possible to set the exhaust valve incorrectly if the compression release isn�t set correctly.. ~Other than that try running it with the exhaust pipe removed, maybe the muffler or pipe is putting enough backpressure on the system to cause the L/H exhaust to flow into or block the R/H exit at the head.. ~I have a couple of 2-cylinder diesels that don�t run even side to side head temperature at idle but that is with water in it so the pony�s warm the R/H sides more then the left.. If I remember correctly the L/H [flywheel side] is the warm one though].. Once they are run under a little load the head temperature evens right out.. If you find a problem let us know as I would be interested in what you find.. [email protected]
