JD 40 Generator
Dave
05-26-2004 06:09:29
I have JD 40 and the generator is outputing low until I speed up the motor. When I turn I the lights is can't keep up. Question can the generator be rebuilt or do I buy another?
buickanddeere
05-26-2004 15:36:13
 Re: JD 40 Generator in reply to Dave, 05-26-2004 06:09:29
The 40's delco model #1101859 6volt generator could make 20.0 amps at 3050 shaft rpm with a tail wind on a good day.
Clooney
05-27-2004 04:16:34
 Re: Re: JD 40 Generator in reply to buickanddeere, 05-26-2004 15:36:13
Glen, a 20 amp generator is actually a pretty good generator output for that era.. Most of the larger lettered tractors didn't even make that 20 amps.. The 40 also runs a fairly fast engine so the generator speeds are up pretty good at operating RPM..
Clooney
tom
05-26-2004 19:12:35
B&D,
The model 40 engine, pretty much the same as the M series, would not command much more than 1800RPM's on a good day brand-new...the system when slated in the high-charge mode would command 12amps at best...so, with those numbers, then you can use John T's numbers and you really start getting low...
I suggest rebuilding the [6-volt] generator and ensuring all of the electrical components [wiring/connectors, fuse, coil, ignition, distributor, battery/cables/connections/ground, gen. & fan belts, etc., are all in superior shape...then see what value a nicely rebuilt generator can do for you.
good luck,
tom
John T
05-26-2004 15:46:48
I hear ya GT, when faced with the reality of maybe 2000 RPM due to some belt slippage and engine loads, maybe 80% efficiency from rated due to loose or worn brushes or a dirty commutator, throw in 4 amps for a coil ignition and maybe 5 to 10 for lights, factor in some resistive relay contacts, n theres not much left huh, and that assumes its even a 20 amp rated Generator in the first place?? And thats on a good day also with a tail wind to maybe help spin the generator a tad lol John T
buickanddeere
05-27-2004 05:42:40
 Re: Re: Re: JD 40 Generator in reply to John T, 05-26-2004 15:46:48
I guess I should have been clearer that 3050 is the generator shaft rpm and not engine crank rpm. They are belted up quite a bit. The stock generator should do fine as long as the belt and pulley isn't worn but most are. May look fine but when measured they are past done and slipping. Seen that on our 40 when run on the standby generator for exteneded periods. The belt was tight but was slipping and made her overheat. Installed a new belt and problem solved. The regulator has to be set to measure 7.2V at the battery terminals at fast idle, most don't however. This explains some cronic 1/2 dead batteries. The other factor is parade and putting around duty just at idle rpms. And those tractors with poor brakes that get shut off & started three times in two minutes just to pass through a gate.
Clooney
05-26-2004 07:28:53
Dave, you ask..
Quote: "When I turn I the lights it [generator] can't keep up" >>>
_ That is pretty normal on a generator system.. Those generators don't produce much voltage/current until the generator RPM's are raised up quite a ways.. You are used to the alternators in the newer cars & trucks that charge good at idle.. There is reason the auto industry went to alternators & one was that poor low RPM charging of generators.
~Don't forget that the headlight load comes off BEFORE the ammeter even reads it so even if the ammeter is at 0 it is still keeping up with the lights. Anything the lights don�t use can then be used towards battery charging & will show on the ammeter..
~If your tractor has extra lights or bigger lights the generator will be sadly lacking, especially at low RPM�s..
~I presume your 40 is still 6 volts? If it�s been converted to 12 volts the generator needs to spin even faster to keep up..
~First make sure the generator belt & idler belt isn�t loose. If all ok there you can clean the generator brushes & commutator & verify the brushes are making good solid contact with the commutator..
~Other than that you can have the generator/regulator tested for max output [but that would be at high RPM�s anyhow & you already know it charges there..
~There are a few things you can do to improve the generator output� The first is to install a smaller generator pulley as that will increase the generator RPM�s VS engine RPM�s & allow it to charge more at a lower RPM.. Check the belts to be sure they aren�t too thin & riding the bottom of the engine or idler pulley, find a better generator with a higher low RPM output [hard to fit on the 40].. Deere offered a smaller generator pulley for the bigger tractors but I don�t ever recall seeing one offered for the 40..
~Welcome to the world of generators..
[email protected]
Bob M
05-26-2004 07:14:12
Dave � I had identical troubles with my Minne Mo UTU (same Delco generator). Problem turned out to be a shorted winding in the generator armature. Replacing the armature with a fresh rebuild ($48 at my local alternator shop) solved the problem.
However before you mess with the generator, temporarily ground the generator field terminal (it�s marked �F� or �FLD�) and run the tractor. If it now charges at a high rate it means the generator is fine � problem instead is a bad regulator.
John T
05-26-2004 07:05:50
Dave, if it were mine, I wouldnt be in any hurry to rebuild it or buy another just yet. First I would:
1) Inspect the belt for it being good n tight and not glazed and the pulley not beign all worn and cupped out. A simple loose or bad belt could be the whole problem.
2) Inspect, clean and air out the generator in its brush and brush hold down area. The brush hold down spring assemblies need to be free n clean so they exert good pressure on the brushes down against the commutator. Ive had many that wouldnt charge and all I did was clean n free the brush hold downs and the commutator and they charged. The brushes cant be worn down too low and the commutator has to be reasonably clean and free of residue, carbon or oil etc.
3) I would inspect the battery to make sure it has electrolyte above all the plates and that no cells have a gray or milky color. A BAD BATTERY MAY NOT TAKE A GOOD CHARGE Maybe have a shop load test it and check it out!!!!
4) I would insure BOTH the Generator and Voltage Regulator have a good ground, maybe loosen and clean n wire brush and reattach the mounts n bolts etc.
5) I would check the Gen and VR connections and terminals, mabe tighten or remove, clean n retighten.
6) I dont think you have a 3 brush Generator, but Ive had tractors with 3 brushers that still used a VR and had tractors that had a 3 brusher from a salvage yard installed etc etc, but if it is, I would adjust the third brush close to the other for max charge.
IF ALL THAT CHECKS OUT AND SHE STILL SHOWS A WEAK CHARGE. I would see if its a Gen or VR problem per the below.
7) With the tractor running, temporarily ground the Gens Field post direct to its case and see if she charges more then??? If so, the VR may be bad or theres a bad or missing wire from the Gens Field to the Field terminal on the VR.
8) With the above shorted field still in place and tractor running, temporarily by pass jump the VR's internal cutout relay by wirign the VR's BAT terminal to ts GEN (or ARM) terminal and see if it charges better then??? If so the VR could be bad (relay contact points burned or carboned resistive etc)
9) If you cant get at the VR very well, step 8 above can still be accomplished by wiring the VR's BAT terminal direct to the Gens Armature post or the feed wire to the battery (load side of ammeter) direct to the Gens Armature post. (That should be same point electrically as the VR's BAT terminal if the wires are all good) All youre doing is by pass eliminating the VR's cutout relay for any problems it may have. For the Gens output to get to and charge the Battery, the ARM post has to get to the battery, and the usual path is to and through the VR (BAT and ARM terminals) to and through the ammeter,,,,, ,to the battery, maybe via the starter post.
10) With the Gens Field dead grounded and its cutout relay by passed, you have essentially taken it out of the equation, so if she still charges weak, youre left with a weak Generator Orrrrr rrrrr r you could have a leak or short in the switches or wiring thats zapping power. If the tractor sets, does the battery slowly or rapidly discharge????? ???? If so, you could have a short or a sticking cutout relay problem and NOT a Gen problem !!!!! !!!! When you shut the tractor off, does the ammeter go to zero or show a discharge????? ?????
Finally, so long as it charges versus discharges and at least keeps up and the battery dont run down, you may not have much of a problem at all, only a low output Generator (maybe its a low output or was replaced with an incorrect one???) assumign the belt and battery and grounds are all good. Maybe a good tight belt and checking the grounds and connections and battery or cleaning out the brush area is all thats needed, simple as that (we hope)
Try some of the above and post back or e mail your results and any questions to [email protected].
Let us know, Good luck n God Bless
YES, it can be rebuilt if needed and YES you can buy another, but I would try all the above first.
John T
