F.I.T. and lye gravy
Mark Scholten
05-25-2004 15:14:52
Frank:
I want to thank you for your lye gravy recipe. I tried to sand blast my wheel centers and used 80 pounds of sand and blasted an area about 12" long by 3" wide. I looked at your web site, picked up the ingrediants, mixed it up and smeared it on and couldn't keep my brush off of it. I was amazed at how well it works.
Hat's off to you and all the others that give us tips to make our lives easier.
By the way, do you get along with your mother in law?
Mark Scholten
Sparta, Michigan
Lye/H3PO4 Sources
05-26-2004 08:33:30
 Re: F.I.T. and lye gravy in reply to Mark Scholten, 05-25-2004 15:14:52
I buy my lye (Red Devil is a popular brand, but it doesn't have to be) at my local Publix Supermarket. I have also seen it at Lowe's and Home Depot in the drain cleaner section of the plumbing department. I have also found it at Ace Hardware. It really should be in the same area as the Drano. You can use Drano, just that it is a bit more expensive, and it has some black and grey specks in it , which are Magnesium Sulfate, but it won;t hurt at all).
PHOSPHORIC ACID, H3PO4
The Phosphoric Acid that I have used is a greenish liquid, with a viscosity about half-way between water and dish soap. It generally comes in quarts and gallons (a gallon will last a long time or do about one very rusty tractor...).
I have found Phosphoric Acid most recently at my local Home Depot in the paint prep chemicals section, and the name of the product was "PH-OSPHO-RIC PLUS+�. I have also purchased a product called "Metal-Prep" at a car show, and it is now carried at my local Bumper to Bumper dealer. "OSPHO" is a brand that is carried at many automotive paint supply stores (like your local DuPont retailer). I bought another product called �THE RIGHT STUFF METAL DE-RUSTER� at the local Discount Auto Parts. They have since been purchased by Advance Auto Parts, and now they only to carry it at some stores in quarts. �THE RIGHT STUFF METAL DE-RUSTER� is manufactured by CLI, and they have a web site :>Link
It seems to run about $7.00 a quart, and $14.00 per gallon.
I'm told "OSPHO" is also available at Ace Hardware.
Let me know if I can help with anything else !
Frank Boerger
Ol Chief
05-25-2004 20:55:16
Info for Mark Scholten.I am in shock that the auto supply charged such a price for phosphoric acid.I have paid $30.00 per gallon for the straight stuff from a chemical supply company.However Ospho is a trade name phos. acid which is 74 % with a buffer added.I pay $17.00 per gallon at my local hardware store here in Texas.I went to sea all of my life and we used Ospho by the drum to fight rust and as a prep before painting.It works wonders on old paint with lots of oxide build up.Often it is cut with water 50% and will remove 0xide and stains generally in about 30 minutes.Generally all thats needed is a water flush and run over it with a soft mop or rag. I have used Ospho full strength on light surface rust and it has held the surface clean for several weeks until I had an opportunity to paint.
Bob Collins
05-25-2004 18:35:28
Mark, I enjoyed looking at your tagless '52 B on saturday, I was hoping you would be around while I was there but guess I missed you. What number cultivator is that? Bob
Mark Scholten
05-25-2004 19:38:03
 Re: Re: F.I.T. and lye gravy in reply to Bob Collins, 05-25-2004 18:35:28
Bob:
I believe it is a model 200. Maybe someone can verify that for me. 2 row mounted cultivator for an A or a B.
Sorry we missed each other. We loaded up at 4:30 and went back home. That was a nice show for their 1st one. I hope to have the LA and the D done for the Muskegon show. If you want to see a nice show, that is a good one.
Mark
Buck
05-25-2004 16:40:20
I would like some information on this recipe.
I have two old B's, one a 1939 with origional
flat spoke wheels. Does this recipe remove the old paint and crud?
Can I get the recipe?
Thanks,
Buck
Brent
05-26-2004 07:53:55
 Re: Re: F.I.T. and lye gravy in reply to Buck, 05-25-2004 16:40:20
Just my 2 cents, I used lye concoction on wheels and rims on winter project, treated with phos, primed painted, total investment about $25, excellent results. Was short of time on next project, so I removed wheels, rims and a few other items and sent to commercial shop. They blasted, painted and primed, total bill, same work, $497.50.
I keep a dipping pail for small part with lye mix, dip small parts and clean up with wire brush or small sandblaster. Works great, inexpensive.
F-I-T
05-25-2004 16:59:57
Buck:
I have the information posted on my website under "Restoration Tips".
See the link.
Frank
Russ
05-25-2004 18:49:43
 Re: Re: Re: F.I.T. and lye gravy in reply to F-I-T, 05-25-2004 16:59:57
I certainly am IMPRESSED! What kind of store carries the "lye" and "phosphoric acid"? I don't remember ever seeing these in my area(Pennsylvania).
Mark Scholten
05-25-2004 19:42:15
 Re: Re: Re: Re: F.I.T. and lye gravy in reply to Russ, 05-25-2004 18:49:43
I found the lye at Ace Hardware. I think any "good" hardware store, Home depot, Lowes, that sort of place should have it. Look in the drain cleaner area. I had trouble finding the phosphoric acid but went to an auto parts store and they sold me a metal prep. $20.00 a quart but I only used about 6 ounces on both wheel centers.
Russ
05-26-2004 17:46:25
 Re: Re: Re: Re: Re: F.I.T. and lye gravy in reply to Mark Scholten, 05-25-2004 19:42:15
Thanks a bunch!
Buck
05-25-2004 18:39:32
Thanks Frank.
Nice web site you have.
I have a 1948 A as well.
When I bought it, The guy told me it would only run a short
time and then quit. Seemed to run better when
cold. Now would not run at all for him.
I looked at the sedament
bowl and it was black. and made the decision
to buy it. I Cleaned the gas tank, lines, sedament bowl,
They were full of a tary substance.
charged the battery, hit the starter and
it was running. The A will do a lot of work.
Thanks again for your recipe, I plan to try it.
Buck
F-I-T
05-25-2004 16:26:46
Mark:
Glad the "stuff" worked for you. Depending on the paint type, the results can border on amazing.
You asked:
Well, my Mother-in-Law passed away many years back, but I tell can you that at our first meeting, when I was first introduced as their daughter's new "steady", we were all trading quips and stories, and I said, "Hey, I heard a cute Polock joke".
Well, the room fell silent and she said very cooly, "I'm Polish, do you mind?"
I paused for a second and replied "No, I'll tell it slow."
My future Father-in-Law fairly spit his beer across the carpet, and then headed to get himself and me another one.
Ha!
Frank-in-Tallahassee
