720 electric start..John T.... Clooney
jdman(MO)
05-25-2004 10:59:59
Have John T's schematic on 720 but it does not show a ammeter. Also on the Generator is A2 the same as return on the schematic and go to the ground terminal on the REG? Russ
1957720D
05-26-2004 20:04:37
 Re: 720 electric start..John T.... Clooney in reply to jdman(MO), 05-25-2004 10:59:59
I have a 720 diesel with pony start. It has a 6 volt positive ground "positive cable attaches to frame". It does not nor did have an idiot light from the factory. It has an ammeter. 6 volt= 15 amp ammeter, 12 volt = 60 amp ammeter, 24 volt = 120 amp ammeter. When you double the volts you double your amp output. I don't know about elec. start 720 diesels but if it is simmilar to the pony start type there is a place for an ammeter and there is no idiot light besides the big red one that tells you the pony ignition system is on.
1957720D
John T
05-25-2004 16:21:15
Russ, the schematic shows an idiot light NOT an ammeter. You have both??? However, if you have one I will have to e mail you a schematic of how to wire it. (I dont show any schematics with both whatsoever) Its no tellin what modifications may have been made over the years, and usually a tractor doesnt have BOTH an idiot light plus an ammeter, but its nothin I cant design and/or furnish a how to wire schematic for.
I show a brown wire from the Generator to the side of the VR (NOT the BAT, GEN, or FLD Terminals) BUT its not a ground, those 2 wire 24 volt generators and starters are frame isolated NON GROUNDED DEVICES.
[email protected]
I will design an ammeter circuit if you use it plus an idiot light.
John T
Clooney
05-25-2004 12:18:23
Russ, it sounds like you have one of those cover all Deere generic wire prints that cover multi models..
You ask..
Quote: "Have John T's schematic on 720 but it does not show a ammeter" >>>
_No ammeter used on the electric start 720.. It uses an indicator light..
Quote: "Also on the Generator is A2 the same as return on the schematic and go to the ground terminal on the REG?" >>>
_There really isn't a return on the 720D electric, there is a brown wire that runs from the generator's A-2 post to the side of the regulator body.. That isn't a ground connection as the 24 volt side of those 24 volt systems doesn't have a ground [both the regulator & generator are completely electrically isolated from the tractor chassis.. The generator�s A-1 post wires to the regulator�s [GEN] terminal with a white wire..
~If you need a better wire print just let me know..
~Don�t forget to polarize that generator before stating or running the tractor..
Any questions just post back or E-Mail..
[email protected]
jdman(MO)
05-25-2004 12:58:15
 Re: Re: 720 electric start..John T.... Clooney in reply to Clooney, 05-25-2004 12:18:23
So why would this tractor have both a generator light and ammeter? It looks like the ammeter has been in there from day one. Is there no schematic tht shows how to wire up an ammeter on electric start 720? Help. Russ
John T
05-25-2004 16:09:54
 Re: Re: Re: 720 electric start..John T.... Clooney in reply to jdman(MO), 05-25-2004 12:58:15
Russ, I can e mail you how to wire an ammeter, its not all that hard. Also, its no tellin how the tractor may have been wired or jury rigged over the years and you may have some original and some that was added on. You are right, usually they dont have both, so do you want to still use both or not?????
Let us know how you want to end up and we can figure it out Im sure.
John T
Mike M
05-26-2004 06:08:47
 Re: Re: Re: Re: 720 electric start..John T.... Clo in reply to John T, 05-25-2004 16:09:54
Wouldn't it have to have 2 ampmeters installed ?
one for 12 V pos. and one for 12 V neg. ??
jdman(MO)
05-25-2004 17:16:29
Thanks so much for your patience. No I just want to use the Ammeter. Also I found from talking to a 720 collector that the panels that are used on the pony and the electric are the same, you just knock out a plug if you want to install a meter. The other thing is that the tractor is wired backward from the battery per the schematic. negative on the battery goes to the starter and positive goes to the solenoid,does it make any difference? Russ
buickanddeere
05-25-2004 13:42:34
If the ammeter wasn't from the factory a good tradesman with quality tools could add one and make it look origional. All it has to do is be in series with either lead from the generator on the way to the battery. Wouldn't be more than 10 amps stock at max output unless the late 840 24V generator windings were used. Up to 18 amps at 28.8 volts. A good idea when building any 24 generator.
