Early Styled B
Jason Z in MO
05-25-2004 10:58:42
I ordered some more parts from John Deere this weekend. I am replacing the front wheel bearings and seals. The original used two felt seals which is the John Deere replacement. Are modern seals recommended?
If so, will an auto parts store be able to match them based on inside and outside diameter?
Thanks for everyones help!
Jason
Bguy
05-25-2004 11:42:27
 Re: Early Styled B in reply to Jason Z in MO, 05-25-2004 10:58:42
Jason, I don't know if they have modern type seals that would fit but the felts ones work pretty good which is what they came from the factory with. I have never had a problem with the felt seals and I don't really see what you would gain by using another type.
Jason Z in MO
05-25-2004 12:02:32
 Re: Re: Early Styled B in reply to Bguy, 05-25-2004 11:42:27
My thought was the felts could soak up moisture. Once this thing is done it won't be going through any creeks anyway!
I know, the Deere engineers knew about water too... :)
I recall an article I read about restoration and they author commented on using modern seals in place of felt, cork, etc. This was to eliminate leaks which won't be an issue with wheel bearings but thought the question was worth asking.
Clooney
05-25-2004 11:38:59
Jason, you might be able to find a modern seal by using the hub & stub axle ID/OD dimensions then calling a local bearing wearhouse. There is nothing wrong with the original felts as they won't cut into the stub axle if mud finds it's way into the seal area.. Also with the greasable hub fitting it might be possible to blow a modern seal out if too much grease pressure is used.. With that large hub hole & small axle stub diameter there would be a large piston area on a modern seal.. Also most of those old stub axles are pretty rough & not real hard so a modern seal might not last very long..
~What I usually do is use one new felt & one old original felt on each side, that seems to be just about the correct thickness to fit good & allow an easy proper wheel bearing adjustment�
[email protected]
Jason Z in MO
05-25-2004 11:45:50
 Re: Re: Early Styled B in reply to Clooney, 05-25-2004 11:38:59
Clooney,
Thanks! Your points all make sense. I was wondering about the longevity of a new seal with this older application. I think you answered it just fine.
I am all about keeping it original but where modern improvements will help preserve the restoration I am would like to understand the pros and cons.
