JD 70 Pup Engine
Art Niska
05-25-2004 08:19:45
How do you drain the oil from the pup engine ? I do not have an operators manual.
John T
05-25-2004 16:24:16
 Re: JD 70 Pup Engine in reply to Art Niska, 05-25-2004 08:19:45
Art, all the ones I owned I drained the pony down into the engine as Blksmok posted there below. Never had any problems.
Good Luck n God Bless
John T
Clooney
05-25-2004 09:12:05
Art, there are a couple of different ways..
The first is like Blksmok posted.. That means the oil drains into the main engine so you then have to [well should anyhow] also change the main diesels oil..
The second & one I usually use is to use a suction gun [I actually use a large glass jar with 2 hose fittings on the top & put a vacuum source on one fitting] then a hose from the second into the oil fill hole, then suction the oil out through the oil fill hole.. That way the pony can be changed more often than the main engine..
Your choice� BTW the manual doesn�t show that second option..
[email protected]
Russ
05-25-2004 13:23:01
 Re: Re: JD 70 Pup Engine in reply to Clooney, 05-25-2004 09:12:05
Puppy luv; This is the first time I have read an idea from the Clooney Master that really sucks.
I agree totally with this sucky idea for a hard working pup.
Blksmok
05-25-2004 08:38:32
Art..... ..there's a 3/4" hex head bolt on the right lower corner of the pony engine that you thread out and it drains the pony oil into the main diesel engine. You normally have to loosen it all the way and then pull the bolt out up against the stop (a washer) to allow the oil to drain out Just reverse to process to refill.
buickanddeere
05-25-2004 08:23:02
Link
