49 A question
david
05-25-2004 08:15:18
Before I tell you the problem, I will say I have tried 3 different carbs, with all types of adjustements on each. The problem is... while the tractor is running, it pops, and has a CONTINUOUS flame about 3to 4 inches above the pipe. Different carbs, and different adjustments do not solve the problem. You should see it when the motor is revved up and backed off. I need some help because it looks and sound pretty obnoxious.
Jack
05-25-2004 10:37:26
 Re: 49 A question in reply to david, 05-25-2004 08:15:18
Frank is likely correct on the exhaust valve - You should perform a test by moving engine to TDC (all valves closed) & pressurizing cylinder to check for valve leaks (both exhaust & intake). Although your post doesn't specify starvation, a seeping intake could be a problem as well. On the power stroke, a seeping intake will allow enough fuel charge to enter cylinder to create problems on the exhaust stroke due to distributer specs (ie fire-every-TDC system) fire-which can ignite unburned fuel in the exhaust on its way out the pipe. Cheap way to do this is by gutting sparkplug & welding a male air nipple to the remains (if you do not have a leakdown tester). Remove exhaust pipe (and carb) & listen in mainfold for leak. Repeat for each cylinder. If yo have a leak, complete valve job is usually in order, as LT leaks have tendency to burn/warp valves, or make it impossible to grind for proper valve margin.
Another possiblity is an air leak somewhere along the exhaust system, most likely near the cyl head, allowing oxygen to enter the exhaust path when engine is suddenly idled down. This will cause a nasty 'backfire' condition and could also create the conditions you mentioned above.
Good luck
F-I-T
05-25-2004 08:23:20
David:
Arte the exhaust valves set correctly? I you have one hanging open, that could be a problem.
Frank
