4840 cab fan blower
tim
05-25-2004 06:15:23
my fan blower in the cab of my 4840 stoped working the other day what areas should I check to get the fan up and running again, i did put a new fan swicth in but still does not work, is there a way to check if the fan is good or bad before buying a new one, I know there is breakers for the radio, fans, etc is there anything else that can go wrong. when i turn the key on radio, wipers,lights everything still works but the fan. any ideas thanks
Bob
05-25-2004 10:04:06
 Re: 4840 cab fan blower in reply to tim, 05-25-2004 06:15:23
The "40" series cab blower is a MUCH simpler setup than the "30".
Remove the wires from the fan switch that go to the motor, and using a long jumper wire connected to a good 12 Volt source, apply 12 Volts to one or the other wire from the fan motor. One should run it at low speed, and the other high speed. Do not apply power to both leads at once. If it does not run, you'll have to open up the top, and verify that the groung wire from the motor is OK, then replace the motor.
david val
05-25-2004 07:02:31
in order to get access to the motor(s) you have to remove the evaporator cover from the roof.
when you do you can check with a test light if the motor(s) get voltage and earth (-). if they do and still don't work the motor(s) are dead.
you can also connect 12V to the motor leads and see if it works.
david
F-I-T
05-25-2004 06:36:04
Tim:
Years ago I put a new fan motor in my 4440, but I had the tech manual. There was a good section in there about how to unplug it and check it with jumper power to confirm where the problem was. Maybe your dealer would let you take a look at the seciton of the book?
Frank
mike
05-25-2004 10:41:06
 Re: Re: 4840 cab fan blower in reply to F-I-T, 05-25-2004 06:36:04
I think i have a new motor if you ned one.
TIM
05-25-2004 11:59:19
 Re: Re: Re: 4840 cab fan blower in reply to mike, 05-25-2004 10:41:06
IF I NEED ONE WHAT PRICE
