2020 JD LIFT AND STEERING TROUBLE AT THE SAME TIME
Dennis F.
05-25-2004 00:00:55
I CAN CHANGE THE FILTER AND HYD OIL . IT WILL START BACK TO WORKING FOR ABOUT 5 HOURS AND STOP AGAIN . CHANGE THE FILTER AND OIL IT WILL GO BACK TO WORKING FOR ABOUT THE SAME TIME AND STOP AGAIN .I HAVE CHANGED THE HYD OIL 6 TIMES AND STOPS EVER TIME .ALSO HAVE TAKEN THE TOP OFF AND CHECK THE VALVES FOR STICKING . CAN YOU HELP ME WITH TROUBLE ? Thanks
Brokenwrench
05-25-2004 04:04:59
 Re: 2020 JD LIFT AND STEERING TROUBLE AT THE SAME in reply to Dennis F., 05-25-2004 00:00:55
What is the condition of the oil and what does the filter look like? Is the oil milky,or silvery in color? Is the filter dirty,or have a silvery color in it?Are you using the correct oil? If you let the tractor sit overnite,do the hydraulics come back?If it is clogging the filter and you are using the correct oil,the brakes could be worn out,clogging the filter.Some more info might help diagnose it alittle better.
Dennis F.
05-26-2004 05:18:48
 Re: Re: 2020 JD LIFT AND STEERING TROUBLE AT THE S in reply to Brokenwrench, 05-25-2004 04:04:59
BROKENWRENCH , The oil looks new and the filter looks to be clean . i`am useing oil from JD they said was for is tractor . I have talk to the shop here with no help . no coloring in the oil . THANKS FOR ALL THE HELP YOU CAN GIVE .
