50 John Deere pto oil pump
Chuck McDonald
05-24-2004 19:14:24
Hey,
Well, I decided to tear the whole rear cover off and replace the pto oil seal between the rear end and live power clutches. When I took the pto oil pump off and removed the seals (!!!!) I was puzzled. The parts manual only shows a bushing (Pg 60-13 #9) and one oil seal for the shaft (Pg 60-13 #10). Mine had two oil seals with one with the spring visible from one end and the other the opposite stacked on each other. Basically, the two metal bottoms of the seals were touching on each other.
My questions are:
1.) do i need another seal and put it back the way I found it.
and 2.) how should the seal(s) be placed? Should i put the flat metal side in to touch the bushing or the spring/rubber lip side down into the housing?
Thanks
Chuck
chuck
05-24-2004 20:30:59
 Re: 50 John Deere pto oil pump in reply to Chuck McDonald, 05-24-2004 19:14:24
There is also some scoring of the bearings that carry the shaft through the rear end housing between the pto oil pump & live power clutches. It probably wont hurt anything, but since I dont want to do this again, should they also be replaced? What tool do i need to drive them out?
Also, should I put the two seals back in the way the old ones were oriented?
d cotton
05-24-2004 19:59:21
I am in the process of doing what you are except on a 70.. The original seal was a long unit.. the replacement is one thin one.. However good sense applys and use 2.. one to seal the tranny fluid and one to seal the pto oil.. I also used a bit of gasket sealent in the bore before driving the seals in to keep seepage around the seals to a minimum... Just my 2 cents worth.
dennis
Chuck (look at also every
05-24-2004 20:32:46
 Re: Re: 50 John Deere pto oil pump in reply to d cotton, 05-24-2004 19:59:21
When you said "one to seal the tranny fluid and one to seal the pto oil" how do you arrange the seals? Do you have a pic of how this goes?
Thanks
Chuck
DaveWis
05-25-2004 04:42:00
 Re: Re: Re: 50 John Deere pto oil pump in reply to Chuck (look at also every, 05-24-2004 20:32:46
Seals are installed with the lip (open side where you can see the spring) toward what you are stopping the flow of. Hence, the first seal goes in lip first to keep pto clutch oil out of the trans/rear end, and the second one the lip out to keep trans/rear end lube out of the pto clutch. Incidentally, pto clutch oil in the trans/rear end won't be too serious unless the clutch runs dry but gear lube is not good for the pto clutch friction discs.
dcotton
05-25-2004 04:33:50
I put them in face to face as you have described... On the scoring of bearings, i dont have a idea as mine were in good shape....
Dennis
