70D - Oil Disappearing Act??
Gary U in NJ
05-24-2004 19:02:03
I'm due for a break one of these days.....
After all that my JD70D has been through (complete engine teardown)it appeared to be running perfect. Well that was until I noticed that my crankcase oil level seemed to be disappearing. No external leaks, and no blow by out the exhaust.
So I added some more oil (2 or 3 gal. worth) and that disappeared. So I opened up the transmission plug and voila no more missing oil....just misplaced.
So whats the deal folks? I'm too exhausted to crack open the service manual and uncover my latest disappointment. I was sorta hoping to have it ready for the Memorial Day Parades.
Thanks,
Gary
Clooney
05-25-2004 03:37:32
 Re: 70D - Oil Disappearing Act?? in reply to Gary U in NJ, 05-24-2004 19:02:03
Gary, I agree with "blksmok", it sure sounds like that R/H main bearing seal(s)are leaking..
~When you installed those seals did you leave the oil drain back hole open? That is a big problem on those tractors if the new seals are driven in & cover up the oil drain back hole between the seals.
~When you drive those R/H seals in make sure that oil drain hole in the main bearing housing isn�t covered..
[email protected]
Gary U in NJ
05-25-2004 07:52:44
 Re: Re: 70D - Oil Disappearing Act?? in reply to Clooney, 05-25-2004 03:37:32
Great question..... .I can't give a good answer which means there is doubt on my end. Obviously I screwed somthing up, which should be pretty easy to spot. The volume of oil loss is staggering.
One other question would be on oil pressure. Do you agree with the 25psi recommended? I noticed that at high idle mine was at 55psi. I immediatly moved it to 28psi high end and 21psi at low idle.
Thanks!
Gary
blksmok
05-24-2004 20:36:50
Gary...sounds like your crankshaft seals are leaking on the pully side. The oil leaks from the crankcase into the reduction cover and then into the transmission. Had the same problem on a 70D that sat for 5 years w/o running. Get the gear puller ready again. You'll be the world's expert on the internal workings of a 70D by the time you get done with your project.
Gary U in NJ
05-25-2004 07:44:48
 Re: Re: 70D - Oil Disappearing Act?? in reply to blksmok, 05-24-2004 20:36:50
I guess becoming an expert would be a compliment, although I can see that it comes with quite a bit of heartach. One good thing is that it won't be too difficult to open up the right hand side of the tractor. Great to hear from you, how are doing?
Thanks!
Gary
