Brake Linings on 47 B
Chuck in MI
05-24-2004 17:29:50
I just recieved a new set of brake linings for my 47B. My brake shoes have 6 holes each and the new linings are longer and have 8 holes each. My question is do I drill out the extra two holes, or should I cut off the extra lining. Thanks in advance Chuck
M-Man
05-25-2004 18:28:54
 Re: Brake Linings on 47 B in reply to Chuck in MI, 05-24-2004 17:29:50
chuck;
I just did a brake job on my 48 B a few weeks ago. I did like clooneys no. 2 below and drilled for more rivets then used my right angle grinder to taper the linings to fit in the drum so far works good.
Greg S
05-25-2004 07:21:07
Chuck - I agree with Mike. When left longer, the linings will not fit properly within the drum. I too cut the linings, and added a bit of a chamfer at the end. As for where to cut the lining, I made them so they were symmetrical. Each end was the same length as the other. If you are using a hammer and center punch, be careful. The linings are brittle and will easily crack if you go too far. Using a Little Giant rivet setter seems to be a good way to go. The local Deere dealer uses a device that looks like a heavy duty C-clamp.
Mike M
05-25-2004 06:03:47
The brake shoes were as you described on my 1945 B when I did them. I drilled the extra holes but then I found out why they were made like that(shorter)the brake drum would not fit down over the linings it would catch on the lower edges. So I sawed them off to match the originals and knocked out my extra rivets and all fit fine just like it was originaly made to do.
John T
05-24-2004 20:00:14
Chuck, its been a while, but as I recall, on the last set I did, I drilled the extra holes and riveted them on same as the others and I never had a problem. Hope that works for you also.
Good Luck n God Bless
John T
Clooney
05-24-2004 17:38:35
Chuck, Deere purposely cut those �B� brake linings short so the brake pinion/bull gears wouldn�t get damaged if a brake was quickly jammed on with force on a spinning wheel..
~You have a couple of choices,,
1)- drill a couple of extra holes & add extra rivets..
2)- do the above & grind the lining back on the long end so it isn�t so aggressive..
3)-just cut the lining back to begin with..
~I usually add the extra rivets then just take it easy on the brakes if stopping a spinning a wheel on ice or in mud..
[email protected]
