Power Steering on a 70
Buddy
05-24-2004 14:11:55
My power steering works great turning to the right and back from right to center but not to the left from center. Is there an adjustment? Thanks
Clooney
05-24-2004 18:18:54
 Re: Power Steering on a 70 in reply to Buddy, 05-24-2004 14:11:55
Buddy, you ask..
Quote: "My power steering works great turning to the right and back from right to center but not to the left from center. Is there an adjustment?">>>
_Well, yes & no.. There are some adjustments that could help but your basic problem is probably a worn helix screw tip, or worn helix pin, or worn sleeve pin that goes in the cam slot..
~You can try removing the helix screw & re-grinding the point on that, then setting the actuating sleeve end play [fore/aft play] to .002�.. [set the worm bearing end play first]..
~Seeing as you have a one direction problem you could also have loose worm bearings as that will effect the actuating sleeve end play also.
~Sometimes just setting the flow control pressure up a little will make the problem better [it isn�t a real repair but increased operating pressure can cover up a worn pin problem as it will turn out before the pin can hang in the sleeve slot..
~My guess is you have a combination of problems that add up to your lack of assist in one direction.. Probably excess worm bearing end play, worn helix set screw tip [& probably a worn helix slot in the sleeve], worn actuating sleeve slots & pins, & possibly some steering vane leakage..
~It sure wouldn�t hurt to do a steering vane leakage test before anything else..
~I would have to type a novel to talk you through all the above repairs & checks & even then you would probably need pictures for some of the adjustments..
~I am going to suggest you buy at the very least an I&T shop manual [JD-10] as it will do a fair job of walking you through the above checks & settings.. Better yet would be the Deere steering service manual SM 2050 [more money though]..
I will be happy to answer any of your questions on your steering but a how-to on checking, setting & adjusting that steering would get real long winded..
[email protected]
