820 front weights
JDBert
05-24-2004 13:06:41
Did they make any other front weights for 820's otherthen the one under the front nose piece? Front wheels kinda look like they are set up for weights.
Brandon
05-24-2004 23:54:17
 Re: 820 front weights in reply to JDBert, 05-24-2004 13:06:41
There were front wheel weights for the 80-820-830, casting number B2016R, 100 pounds a piece. SOMEWHERE I have pictures of a 820 fitted with them. If I find them, I'll post. They do look neat!
Brandon
My Industrial John Deere website
John Deere Diesels
The LaGrange Engine Club
720Deere
05-25-2004 05:33:52
 Re: Re: 820 front weights in reply to Brandon, 05-24-2004 23:54:17
While those weights will work on the 80/820/830, they were meant for the 840 industrial version. Even though they would not be "correct", it would be an awesome looking addition to any one of those tactors. They are probably harder to find than most pony motor parts.
Brandon
05-25-2004 12:13:28
 Re: Re: Re: 820 front weights in reply to 720Deere, 05-25-2004 05:33:52
The B2016R wheel weights are in the 80-830 parts book, and I also have a indusrial brochure that mentions there use on an 820. I'm sure they were acceptable to use for a farm tractor too. Though most farmers would probably just add calcium, since that would cost less.
I still haven't found my photo of the weights! Where o where did I hide it!
Brandon
Mark
05-24-2004 20:13:17
IF the wheel weights from a JD 4400 combine fit and I think they might...I have a set of 4 half pieces for sale...they might be 50-60 lbs each half....someone on here will have to tell us if they work.
buickanddeere
05-24-2004 13:32:12
Combine wheel weights bolt onto the front rims. What are you hauling to get the front end light?
JDBert
05-24-2004 14:28:58
 Re: Re: 820 front weights in reply to buickanddeere, 05-24-2004 13:32:12
Nothing just want it to look cool, gonna have 4 on each rear wheel and was wondering what front weights would look like. Plus it gives some people something to talk about, especially "correct police" who I usually like to tell to get lost since its my tractor. Which weights are they? off of what series?
buickanddeere
05-24-2004 16:34:54
 Re: Re: Re: 820 front weights in reply to JDBert, 05-24-2004 14:28:58
I have a couple of rough 840 industrials here. They pack a mean "I" beam front bumper and about 1/2 ton of slab front weights. Might make a beastly looking bolt on for your machine. The extra weight does make the tractor feel fat and lazy having to haul the extra weight around. Pulling the 840's with the 435 on level ground was a demonstration of HP lost due to rolling friction. Made it scratch up the gravel on level ground when starting off and lugged the engine on a modest hill before she spun out.
