2440 brake question.
Indydirtfarmer
05-24-2004 10:45:14
My 1978 2440 (No hi-low, Ind. PTO) seems to need brake bleeding every 50 to 75 hours. It's not a bad problem, just doesn't seem "normal". Oil levels in the hydraulic system are normal. It's clean and filters are changed regularly. The brakes work great. There are no brake material pieces in the oil. Is this normal? I haven't ever had this "problem" with any of my other Deere tractors. (4020, 4440, and 4955) I use this tractor a lot. It's hay season, and I don't want to do any damage to the brakes if there's something amiss. Thanks. John
david val
05-25-2004 07:24:55
 Re: 2440 brake question. in reply to Indydirtfarmer, 05-24-2004 10:45:14
frequent brake bleeding indicate leaks. one source for air entrance is bad or damaged finish of the brake valve pistons. other point of entry is brake pistons leaky seals.
brake seal problems were increased significantly when 'o' rings were used instead of packings.
john deere introduced at the time kits that raised the oil level at the brake valve reservouir. the raised oil level prevented air from entering thr brake system, thus preventing the need for frequent bleeding without actually stoping the (small) leaks.
the principle of the kit was a 1/2 inch hose connected to the top of the brake valve and reaching the top of the battery box, where oil was supplied at a small rate from a special fitting at the top of the oil reservouir above the hydraulic pump. when the brake valve and 1/2 hose were full, exess oil flew through the transmission shift cover back to the transmission.
brake valve gasket was also changed to plug the brake valve supply and drainback openings.
david.
chris
05-24-2004 20:20:41
Remove the top and bottom plugs(4) and clean the valve out, the valve gets its oil from the return oil of the steering and the brake valve collects alot of debris since its low and debris settles there. Get an parts picture and remove/check the valves while plugs are out and wash out. Fixed a few this way. chris
WTW
05-24-2004 14:30:59
Here is a possibility if you are sure you are getting the brake bled and the problem returns. If you have a warped brake disk the dish shape of the warped disk act as a bevel type spring washer and causes the brake piston to return to far back into piston bore. This may take hours for this to happen. To collapse or flatten the warped dish shaped brake disk against the backing plate it will take the full amount of oil of one brake pedal application can supply to due so, and the second pump will actually build pressure to apply the brake when disk is flat against the backing plate. Normally the disk is flat and the brake piston travels little to none to pinch the disk no different than a disk type brake on an automobile. Have seen this a few times over the years usually occurs when a brake pedal does not return all the way back up correctly not allowing brake to release causing brake to drag causing disk to warp. Good Luck, Dave W.
G-MAN
05-24-2004 10:50:10
Is it just one side or both? One side would tend to point toward a problem in the valve or with a leaking piston seal or possibly a problem with that section of the brake valve. Both would seem to indicate a problem in the valve itself. I suppose it's possible that both piston seals could be leaking, but that would seem unlikely. I wouldn't think that damaging the brake system would be a concern either, as they should apply themselves with air in the system.
Indydirtfarmer
05-24-2004 11:02:40
 Re: Re: 2440 brake question. in reply to G-MAN, 05-24-2004 10:50:10
The problem seems to be with both sides, but the right side is effected more. The pedal will go almost halfway down, then with a quick pump, get a firm pedal. The left side will only go about half as much as the right in the same ammount of time. John
