430 U john derre
David in Tn
01-27-2004 15:51:23
Does any one know anything about the direction reverser? Is this something only a few tractors had? How rare is this to find a tractor with this option?
CPeter
01-28-2004 05:30:55
 Re: 430 U john derre in reply to David in Tn, 01-27-2004 15:51:23
It is not unusual on either a utility or crawler that nwould be subject to a lot of back and forth work. If you get into the tractor, be sure to check it out for chipped teeth and worn bearings and clutches. The later ones on the late 420s and 430s were much better than the early models and used clutches to do th shifting. For a machine used in shuttle work, it is a nice feature. Treat it with respect and if it is good shape now you should not have trouble with it. Don't do the power on reversing as that really works the unit hard. Come to a complete stop and then reverse. There is a lot of energy stored in that flywheel and sudden changes in direction put extreme loads on the drivetrain.
If it does give trouble and you want to remove the unit, I THINK(not positive, but pretty sure) that a regular drive shaft can be used to replace the reverser.
CPeter
