Tom, you could have a sticking intake valve, carbon under an intake valve, worn intake valve guides, worn cam shaft, out-of-time cam shaft, ignition problem, vacuum leak, worn carb throttle plate, leaking intake manifold gasket, worn top ring groove on a piston, or??? ~Start with an old spark plug,, break the center porcelain out of the plug & braze on an air hose fitting that will fit your air compressor hose.. Then roll one cylinder to TDC [both valves closed] & put about 50-60 psi in that cylinder.. Where the air comes out will tell the story.. If both cylinders seem about the same [a little ring leakage is normal] then remove the air & pull the valve cover & push on the valves & look for a sticking valve, weak valve spring, excess valve to guide clearance etc.. ~If still nothing found suspect the carb or even a weak mag.. ~To test the mag--- take an old spark plug wire [metal core],, then cut that wire about 2� from the spark plug end,, then strip the cut ends back so about �� of metal wire sticks out of the cable insulation,, then push the cut back insulation ends into a piece of clear plastic tubing so the metal ends are about 3/16� apart.. Now install that �special� plug wire in on one side at a time & run the engine at low idle in a dark area.. If your ignition system is producing enough spark you should have a good constant bluish colored spark jumping the 3/16� gap every time that side cylinder is supposed to fire.. If the spark is yellowish, wimpy, or intermittent suspect low mag output at idle.. NOTE: you can�t just use cranking spark output as the mag impulse will increase the spark at cranking speeds.. Probably the lowest spark on that mag will occur at idle speeds just above 250 RPM.. ~If the ignition system checks out good then maybe do a cam timing check��L/H ex. Open� mark on the flywheel lining up with case mark VS. �O� lash on the L/H exhaust valve. ~If still nothing found try pulling the choke almost all the way back on .. If it then idles better suspect a carb idle problem or vacuum leak.. If a vacuum leak is suspected use an un-lit propane torch & run some propane around the manifold & carb joints & see if the idle picks up,, if so suspect a vacuum leak in that vicinity.. ~Use some of the above & see if you can pinpoint the root of the problem.. If you find a system that changes the idle for the better [or worse] post back or E-Mail for further diagnostics for that area.. ~Here�s the bottom line--- You need a good strong spark,, at the correct time,, with the proper fuel/air mixture present,, with enough compression to utilize the fuel/air ignition power.. What�s not working correctly? ~One more possible problem area.. If that intake manifold hasn�t been removed in years it�s very possible that the inside of it has become excessively coked up inside the passages & that limits the amount of heat on the intake to properly vaporize the fuel air mixture & that can cause very poor idling [somewhat common on lightly used D�s].. Any questions on the above just post back or E-Mail.. [email protected]
