Phil I just got back from the barn and looking in the manual. Good to hear that you are using one also. My second thought would be that even though you set the valves - I think you have the wheel type of mechanish, you did not actually move the valves. Did you see the cross over valves actually go in when you tightened the wheel? They sure tend to get stuck and you think they are not supposed to move. If they are stuck you gotta get them moving. I would use some of your favorite nuts off stuff and get them rotating. I would also be careful not to pull them out - like ooops darn I did not mean to pull it all the way out lol. I don't know if i am hitting on the possible problem or not. If you got a decent parts man at your dealer, you could take the block off that the valves go thru and replace the seals. But, if it aint broke, maybe you don't need to fix it. Now for the "jinking up and down" , if the cross overs are working that may be an entirely different problem. I foggily recall a blurb somewhere in my service book on the usual cause for the up and down jinking. Let us know how it is going. good luck
