HELP!! JD 2010RU 11 Clutch pressure plate
Britt
05-23-2004 17:26:29
I am replacing the engine in a 2010RU. While it is out of the tractor, I thought that it would be a good time to replace the clutch, pressure plate and throw-out & pilot bearings. The tractor has the optional 11" heavy duty clutch. The pressure plate assembly has an internal spline that drives the live hydraulics and PTO. JD list on the pressure plate $435.00. List on the clutch disk is $130.00. Does anybody know where I could find rebuilt/exchange units at a more reasonable price?
Bob
05-23-2004 18:20:32
 Re: HELP!! JD 2010RU 11 Clutch pressure plate in reply to Britt, 05-23-2004 17:26:29
Depending on which clutch you have, you may be able to get the back part of the pressure plate that the PTO drive hub is riveted into for $110.00 from Deere. You would have to transfer over your actual pressure plate and springs, and reset the clutch fingers to spec.
Brokenwrench
05-23-2004 17:49:09
Find a shortline dealer or distributor that carries Hi-Capacity,or A&I Products for aftermarket replacement. If your pressure plate is not worn,hot spotted,or grooved it can be reused with a new disc and TOB.
Britt
05-23-2004 17:54:24
 Re: Re: HELP!! JD 2010RU 11 Clutch pressure plat in reply to Brokenwrench, 05-23-2004 17:49:09
The pressure plate is in good shape WITH the execption of the splines that drive the PTO/hydraulics. They are badly worn. Does Hi-Capacity or A&I Products supply these pressure plates?
Thanks,
Britt
