47' D clutch adj.
Paul.D.Canada
05-23-2004 15:30:35
I put all new clutch facings and facing disk in my 47' D today.When I went to adj the clutch as per the manual, I can only get the the nuts on up to the castle part of the nut for the clutch lever to work properly.Can soneone tell me what I am doing wrong? When I took it apart it(the nuts) was the same way(no cotter pins).Could there be something wrong further in?(beyond the pulley) The clutch lever seems to snap in okay but I didn't want to start the tractor until I got an answer to this. Thanks in advance Paul.
Bob-Wyo
05-24-2004 20:07:57
 Re: 47' D clutch adj. in reply to Paul.D.Canada, 05-23-2004 15:30:35
Paul D. The "TOTAL" length I get is 6 3/4", and I'm pretty sure it is from a 38 D.
They were the same from 31 up, D1709R part num.
I checked with Deere a few years ago and only 2 could be found, 1 in Texas and 1 in Canada for about 40.00 EA.
Hope this is of some help,
Bob
Paul.D.Canada
05-25-2004 18:28:11
 Re: Re: 47' D clutch adj. in reply to Bob-Wyo, 05-24-2004 20:07:57
Bob, thanks for the info this is a big help...Paul.
Clooney
05-24-2004 03:46:45
Paul, there could be many reasons for your lack of enough threads.. From the clutch pack being too tall [or an extra disk], to the incorrect adjuster bolts, to someone having welded something up inside, to ???..
You will probably have to remove the clutch pulley to find the problem.. [hopefully just short adjuster bolts]..
[email protected]
Paul.D.Canada
05-24-2004 06:15:21
 Re: Re: 47' D clutch adj. in reply to Clooney, 05-24-2004 03:46:45
Clooney, when you remove all the guts of the clutch,can you just pull the pulley off?It seems like you can, do you have an idea how long the adj. bolts should be? Thanks again Paul
Clooney
05-24-2004 07:31:16
 Re: Re: Re: 47' D clutch adj. in reply to Paul.D.Canada, 05-24-2004 06:15:21
Paul, you ask..
Quote: "when you remove all the guts of the clutch, can you just pull the pulley off?">>>
_NO, you will also have to remove the front fork bearing to allow the clutch fork to pull out the front.. Then the pulley will just pull off..
Quote: "do you have an idea how long the adj. bolts should be?�>>>
_Not off-hand.. If I get a chance I will try to get you a length as I believe I have an old �D� clutch pulley out in the back barn [somewhere]..
[email protected]
Ralph - Wi
05-23-2004 17:58:00
Did someone substitute bolts from an A or G which I presume are shorter??
