john deere 2640 hydraulic power controler valve
ron v
05-23-2004 15:29:34
1977 2640 keeps blowing nylon o-ring seal.i have checked mounting surface on valve for warpage seems to be ok. thanks for help.
ron v
05-25-2004 11:24:07
 Re: john deere 2640 hydraulic power controler val in reply to ron v, 05-23-2004 15:29:34
this valve is listed in john deere tech. manual as pressure control (priority) valve. it is located under right side footrest. high pressure oil from pump at front of tractor comes direct to this valve
Dieselrider
05-24-2004 04:00:23
Mine leaks around the vertical shaft in the remote couplers. Thinking of ditching the whole system and going with something else that works better. Please let us know what works for you. Good luck.
Bob
05-24-2004 06:53:10
 Re: Re: john deere 2640 hydraulic power controler in reply to Dieselrider, 05-24-2004 04:00:23
That should be an easy fix. Properly replace the "O" rings and backup rings, and inspect the coupler barrel for damage.
Once you get the right rings in there, properly installed, and replace any worn parts, that should end your trouble for a long time!
JMS/MN
05-23-2004 16:51:25
Do you mean the remote hydraulic coupler? A rough, damaged hose tip can pop out those rings.
Bob
05-23-2004 15:42:48
You might be a bit more clear as to what cover on what valve???
