Clooney I need your Expertise
Dan The D Man
05-23-2004 12:22:02
Like you said in your last message to me I have gotten the flywheel on my D ready to come off. But how do I get it off? Do I hit it or tap some where? Is there a serton technic to taking it off?
Thanks
Austin
05-23-2004 20:54:19
 Re: Clooney I need your Expertise in reply to Dan The D Man, 05-23-2004 12:22:02
What I have done to remove D flywheels is to take some All- thred or long bolts and thred it into the bolt holes on the flywheel. Then I take a bar puller slide it over the two pieces of All -thred and secure it far enough out to fit a bottle jack in between the bar and the end of the crank shaft. After that I "jack" the flywheel off. Things taht need to be considered. make sure the bar puller is square with the end of the crank shaft by adjusting the nuts accordingly. Also make sure the bar puller is stout enough that it won't bend in half. Finally before you do andthing make sure you have something supporting the flywheel so that when it comes off it will not crush your feet or anything else. I suggest using a crane with a chain looped through the holes supporting it and large blocks of wood under it as a safty precaution.
