Fred: I think I can get you started. One of my favorite tricks that I use to track down a small short is to remove one of the battery cables. Then take a test lamp or an old 12 volt headlamp with some leads attached (I save those dual beams just for this...just be sure you use the two terminals with the good filament). I have also built up a little 12 volt buzzer from Radio Shack to use when I can't see the light but can hear the buzzer. Now, if you have a continuous current flow which is draining the battery, you hook the lamp or buzzer in series (one lead to the battery terminal and the other to the unhooked battery cable). If everything is turned off, no current should flow, and the lamp should not light. If current is flowing (which is bad) the lamp will light. Now if it is, let it hooked up and one by one disconnect a wire (ign switch, light switch, votage regulator) until you find the one that stops the current flow and makes the light go out. After removing a wire, if it doesn't have any effect, you can re-attach it right away, so you don't have more than one loose wire at a time. You can also test your switches this way as you work. As soon as you find out which wire, or wires, are the offenders, post back here, and someone will be able to get you guided toward making the proper repair if it isn't obvious in your troubleshooting. Frank
