1950 JD B still stuck
ED
05-22-2004 17:39:57
My 1950 JD B has been soaking in mystery oil & pb blaster since December. she is still very stuck.putting her in gear and gently rocking her back and forth did not work.also had counter weight on flywheel for months.any thing else i can try before i tear it apart?
TIM
05-23-2004 10:29:16
 Re: 1950 JD B still stuck in reply to ED, 05-22-2004 17:39:57
I haven't tried this myself, but one old boy just told me to try this. Remove the head, then remove the rods from the crank and remove block with the pistons in it. Turn over so you can heat the inside of the pistons with a rosebud untill hot. This expands them and the rings will bust the rust around them. The whill stll hot, dump water down into the piston. He said he has had piston fall out doing it this way and has yet to crack one.
JC
05-23-2004 10:20:57
Ed,
I agree with Harold. I would pull it apart, remove the pistons and clean it all up. Guys on the Cat restoration web-site use a lot of different techniques to free stuck pistons like filling the cylinders with oil and pressurizing each one with a grease gun thru an injector hole, burning fuel on top of the piston to warm it up, etc, etc. If it's stuck, there is likely to be a lot of crud that you wouldn't want pumped past the exhaust valves.
Good Luck!
JC
Harold
05-23-2004 08:18:28
Ed, I have redone seven old JDs, everyone that I have worked on had enough crap in front of the pistons that would jamb them even if you did break them loose. Also the valves are probably stuck too. Take the head off, remove the blcck with the pistons and rods then drive the pistons out of the back of the block. everything will be much easyer to clean up then.---Harold
Russ
05-23-2004 15:08:33
 Re: Re: 1950 JD B still stuck in reply to Harold, 05-23-2004 08:18:28
Don't B Stuck; Harold speaks the truth, follow his advice and do a good repair. Read through the John Deere B repair manual sections several times to fix the process in your mind. Good luck.
donwisc
05-22-2004 22:53:59
If you are willing to take off the head, make up a 2inch hardwood block and drill to match the rod bolts using the old gasket as a template on one cylinder only. Then put a short piece of a 4 by 4 in the cyl , put the 2 inch block over the rod bolts and use washers and the nuts to jack on the piston. I used this method to free up a US A in one day.
If you dont want to take off the head just yet, try circulating water, starting with hot and then boiling water thru the the system. This will possibly cause enough expansion in the cyl walls to allow the pen oil to work or actually free up the piston. Good luck and let us know how it turns out.
Bernie in MA
05-23-2004 18:13:04
 Re: Re: 1950 JD B still stuck in reply to donwisc, 05-22-2004 22:53:59
I did the same thing on my 420C, except I used pieces of steel square tubing. The wood has a tendency to squash. Also, on the hot water I plumbed an old 20# propane tank to the bottom of the block, filled the tank and block with water and heated the tank with a gas burner. It worked and I was pushing rocks out with it today. All I did to the engine was clean up the rusty cylinder wall that had had the water in it.
old
05-22-2004 19:10:35
Fill the cylinders with turpentine, the old type and if its going to pop loose it will with that.
ED
05-24-2004 17:06:39
 Re: Re: 1950 JD B still stuck in reply to old, 05-22-2004 19:10:35
Thanks very much for all the advice.ill let you know how i make out.
James
05-22-2004 18:20:51
You better take it on down and clean and check it all out. It is probably full of rust and other debris that you have killed with the solvents . All kinds of critters get in there .
