Bent roll-o-matic knuckle?
Tye
01-27-2004 14:48:45
third party image
I saw this while doing some repairs on the snowplow earlier this evening. I think I have a bent knuckle or spindle. Does this happen often? Does the right tire look like it's bent slightly out? I placed my hand between the tire and pedestal and the right side is bent out or the left side is bent in. It seems to work fine-just never noticed it before. Should I replace it? Thanks for any input. -Tye
John 51
01-27-2004 18:15:01
 Re: Bent roll-o-matic knuckle? in reply to Tye, 01-27-2004 14:48:45
Yes, that does happen, but the ones I've seen like that are usually due to mismatched wheels with slightly different offset or bent rims.
chris
01-27-2004 16:51:52
Tye, do you have the same style rims on both sides, one may have a different dish/offset to it. Just a thought. chris
Mike in UP of MI
01-27-2004 16:30:23
I just went out and checked the distance between the pedestal and tire on my 1950 "B". The distance between the pedestal and the tire on the right side (pulley side) is about 3/8" wider than the left side. I did not move the tractor or rotate the wheel, so this distance may change as the wheel rotates.
Tye
01-27-2004 19:28:27
 Re: Re: Bent roll-o-matic knuckle? in reply to Mike in UP of MI, 01-27-2004 16:30:23
Mike you brought up a good point. Before I draw any conclusions about this, I'll pull the tractor out and put it on the asphalt tomorrow and check it then. Thanks for the help to everyone. Does this situation pose any long term theats on any parts? Thanks again. --Tye
