1840 JD
Barry
05-22-2004 13:56:24
Could any one give some information on JD 1840 mfd.I am looking at one it has 5000 hrs.,diesel,
with 3pth. and a JD 245 loader,7 ft.bucket,JD bale
spear and JD grapple for the bucket.Tires are worn
paint is good been stored inside.Runs good but the
hydraulic's are slow (0k for awhile then get slow)
on 3pth.and loader.1981 or 1982 model.
Any one know a value,horse power or any useful information would be appricated.Thanks Barry
mark
05-23-2004 15:52:03
 Re: 1840 JD in reply to Barry, 05-22-2004 13:56:24
The 1840,if you are in the states, is a grey market tractor.Nothing wrong with them,but they create the mistaken impression you can't get parts for them.Parts are available,you just need a good parts person that can look them up.It is roughly the same as a 2150 US sold tractor with a MFWD axle. It should be about 50 hp .Its a decent little tractor,if it has had good care,the front ends can be a problem after alot of hours with loader work and are expensive to repair.Your hydraulic problem could be a filter or internal hydraulic leak,a $10 dollar fix or a $500+ fix.I wouldn't want to put much more than $4800-5500 in it,with the hyd. problem and it needing $1000 worth of tires.
