Backhoe
Pete/ME
05-22-2004 03:17:07
Got an old #56 Kelley backhoe for my 4020. The boom doesn't hold pressure--drops when raised. Should I look at the cylinder or the valve body? It did the same thing on the 2240 and has sat for a long while before I bought it.
ET
05-22-2004 18:59:24
 Re: Backhoe in reply to Pete/ME, 05-22-2004 03:17:07
I would repack the cylinder the oil is leakig internally by the piston.
HAVVEY
05-22-2004 05:03:56
I WOULD LOOK AT THE VALVE BODY UNLESS THE CYLINDER IS LEAKING JUST TO START WITH THOSE KELLEYS WERE A DECENT UNIT. WHER IN MAINE ARE YOU FROM I AM IN THE EASTERN PART OF IT?
Pete/ME
05-23-2004 03:37:13
 Re: Re: Backhoe in reply to HAVVEY, 05-22-2004 05:03:56
Thanks to ET and Havvey. Neighbor said to raise boom, chain it off, plug lines to it and see if it drops. Sounds like an easy way to check. Tackling the valve body could get pretty hairy. Havvey, I'm in Whitefield, 15 mi. southeast of Augusta.
havvey
05-23-2004 05:46:44
 Re: Re: Re: Backhoe in reply to Pete/ME, 05-23-2004 03:37:13
over 3 hours away but been there before good luck on the hoe
