60 wheel adjuster
moline
05-21-2004 19:21:35
I have a frozen adjuster on the wheel of my 60.I was able to get the wedge out and roll the wheel around so that the wheel fell against the axle and disengaged the adjuster from the axle teeth.I was then able to slide the wheel off the axle.I have been soaking the adjuster with penetrating oil.I have a helper apply pressure to the adjuster and then I try tapping on the gear(with a brass drift).No luck.Does anybody have any secrets to this problem?Thanks,Moline
Larry
05-24-2004 09:32:06
 Re: 60 wheel adjuster in reply to moline, 05-21-2004 19:21:35
Heat and penetrating oil are good. We also use a 1" drive air impact wrench to get it moving (after wheel is off the axle) and once it does move let the wrench do the work. After it's spinning free, coat everything with never-seize to keep it that way.
F-I-T
05-21-2004 20:25:50
Moline:
The last two I did on my 70 I used penetrant, and some judicious heat, then let cool, then more penetrant. What I finally found to work very well was an air rivetter with a straight shank (I cut the end off an old chisel) and vibrated against the open end of the pinion shaft. Both sat still for about half a minute, then began to move, and then walked right out.
Frank
moline
05-22-2004 07:59:55
 Re: Re: 60 wheel adjuster in reply to F-I-T, 05-21-2004 20:25:50
Frank,Thanks for the info!Are you saying that you pushed the pinion shaft out of the wheel?Mine has a plug in the pinion shaft opening.Should I puncture the plug and remove it?Or do you think by heating the wheel casting I could get the pinion to turn.Thanks,Moline
F-I-T
05-22-2004 09:58:18
 Re: Re: Re: 60 wheel adjuster in reply to moline, 05-22-2004 07:59:55
Mo:
That plug should be an old cork installed at the factory to keep the water out. It's a good sign that yours is still in there, as it might have hepled to keep some of the moisture out. Yes, remove that cork and apply force at that end. You might want to use a brass drift so as not to accidently expand the pinion shaft as you drive it. The little rivet gun with a flat shank worked great for me.
I did heat mine. My experience has been that if you don't have any cracks in the wheel, you should not have any problems.
Frank
