70 lp valves are leaking
Alan
05-21-2004 19:16:15
I need to know if I can rebuild? Or will I need new ones? I have already tried to tighten the big nut behind the knob.Thanks in advance.
Alan
Roger Harcourt
05-23-2004 13:42:31
 Re: 70 lp valves are leaking in reply to Alan, 05-21-2004 19:16:15
Hi Al. I hope you find a rebuild kit for your valve. I just bought one - had to have one- at JD for my 4010 and it was $135.
Alan
05-23-2004 07:54:48
Thanks guys I will pull them off and head to the JD dealer here and see what they can do. Thanks Again
CLW
05-21-2004 22:46:00
Alan, I did the same as Ben. They are not hard to rebuild and the LP dealer knew what they were. I don't know if Deere has them or not. I don't think they do or I would have gotten them there as I was buying other parts at the same time. May be worth a call to see.
CLW
Ben.So.Tex
05-21-2004 19:36:37
I got some new ones from my local lp dealer for my 720 and 730, cost about 25.00 each. take your old ones with you so they can get the correct ones for you. Good Luck Ben.
