74, 400 series JD Loader/Backhoe. HELP!!!!!!
Donna
05-21-2004 08:16:02
We just purchased a 74, 400 series JD Loader/Backhoe, Model M53TW. What kind of fluid does it take, HYD, UTF , HYD & ATF mix? This thing has been running great, but the last 2 times my husband used it, he was just driving along and it just stopped moving. Engine still running, sounds good, no funny noises, not popping out of gear, just stops moving! Any suggestions? Where can I get the manuel for it?
Sorry for all the questions and hope I do not sound too stupid. Thanks, Donna
jdemarra
05-21-2004 12:24:18
 Re: 74, 400 series JD Loader/Backhoe. HELP!!!!!! in reply to Donna, 05-21-2004 08:16:02
You didn't mention what options it has for a drive system between the engine and gear transmission. If it has a hydraulic hi-lo, or a hydraulic reverser, the problem is likely there.
The 400 is basically an industrial version of the green painted ag. 2020. Trans. and hydraulics use "combination gear and hyrdraulic oil" available just about anywhere that sells oil. Of course, every dealer has their own brand, e.g. Deere and Hyguard, IH and HYtrain, etc.
Mike M
05-21-2004 08:21:02
Go to most any John Deere dealer and get some HY-GARD trans. hydraulic fluid. I would drain it and clean the suction screen and change the filter and oil then try it and see if it works better.The dealer should be able to assist you in ordering a book.
