Clutch snapped in, won't snap out
Ben.So.Tex
05-21-2004 04:15:34
I am working on my fathers first tractor 45B,I ajusted the clutch to where it had a good snap, it seem alittle to crisp, I snapped it in yesterday and it will not snap out, It has even bend the clutch rod. What do I have to do to get it to snap out so I can lossen the adjustment? Thanks Ben
Clooney
05-21-2004 06:39:20
 Re: Clutch snapped in, won't snap out in reply to Ben.So.Tex, 05-21-2004 04:15:34
Ben, try pulling the tractor a few feet in high gear while trying to disengage the clutch.. If you have a worn operating sleeve drive pin that might be enough to back-drive the clutch & turn the operating sleeve enough to allow disengagement..
~If pulling it doesn�t help then you might have to lubricate the nuts & try backing them off with the clutch still engaged..
[email protected]
Ben.So.Tex
05-21-2004 19:32:16
 Re: Re: Clutch snapped in, won't snap out in reply to Clooney, 05-21-2004 06:39:20
Thanks Clooney, I removed the cotter pin from the adjustment bolts and back off on the nuts and it came free, Had to go rob a rod off one of my donor tractor to replace the bent one. Thanks Ben
