4320 Hydraulic's
Joseph Stephens
05-20-2004 20:19:59
How do you bleed the hydraulic's on the remote outlets? I have air in the system and am haveing trouble opening my roll bailer to kick out a bail. Thanks.
Brokenwrench
05-21-2004 04:08:16
 Re: 4320 Hydraulic's in reply to Joseph Stephenson, 05-20-2004 20:19:59
Are you sure you have air in the system? If you are trying to open the gate on a round baler with the clutch pushed in,you may not have enough reserve oil in the system to raise the gate.When you hold the clutch in, the charge pump stops supplying oil to the main pump.You may have to put trans in neutral,and raise the gate with the clutch engaged,so the charge pump keeps supplying oil to the main pump.
JMS/MN
05-20-2004 21:48:07
Cycling the control several times should eliminate the problem.
