Don, the first thing to do [look at] is: ~With the engine NOT running, cycle the throttle linkage rods by hand & make sure they move freely with no apparent hang-ups or binding.. Pay particular attention to the throttle rods rubbing on something & that the cotter pin at the throttle lever linkage attaching area isn�t hitting the carb casting [common problem].. ~If the linkage moves nice & smooth & will allow travel to full throttle then you either have a cracked or broken leaf spring on the governor arm, or that spring is installed incorrectly, or a misadjusted throttle linkage or stop bolt.. ~Look CLOSELY at the leaf spring on the governor arm for signs of cracking [usually close to where the attaching bolt goes through].. ~If the leaf spring is ok [& installed correctly] then move the hand throttle lever to wide open, then hold both the governor arm & carb�s throttle lever at full travel [wide open], then adjust the front throttle rod to be between � & 1 hole short of entering the carb lever hole.. Then install & pin that front rod.. ~The above pretty well covers the main linkage adjustment for speed & control.. If you still can�t get wide open throttle then adjust the rear throttle rod length & full travel stop bolt to allow the engine to achieve full throttle & still obtain a low idle.. ~At one time Deere offered a little stiffer governor arm spring to help a low power & low RPM condition but I doubt that spring is still available.. **Any questions on the above just post back or E-Mail.. [email protected]
