t.. coffman, that 24 volt 730D of yours is both a positive & negative ground tractor.. That�s a little different than used on most other equipment.. ~On half of the batteries & one half of the electrical system uses 12 volts negative ground... The other half of the batteries & electrical system uses 12 volts positive ground & the starting & charging system use all the batteries in series for 24 volt starting & charging.. It seems complicated up front but once you understand it, it�s not that bad.. ~That 730D essentially uses 3 separate electrical systems [all interrelated but isolated from each other].. That tractor used one 12 volt system to power � the lights, fuel gage & accessories, the other 12 volt system to power the other � of the lights, accessories & rear lights.. When the starter button was pushed all the batteries were used in series to power the starter & of course the generator needed to charge all the batteries in series at 24 [actually 27-28] volts.. ~The 24 volt part of the system is COMPLETELY isolated from the tractor chassis with no part of the 24 volt side touching the metal tractor chassis [starter & generator are isolated from the chassis] .. The 12 volt sides do have return to chassis grounds [one positive & one negative].. ~Your 730D originally came with 4- 6 volt batteries wired in series with 2 batteries providing � the 12 volts & the other 2 providing the other 12 volts.. The left 2 batteries supplying the positive ground part & the R/H 2 batteries providing the negative ground part.. There was a small connector wire hooked between the center 2 battery�s connector battery cable & seat box ground.. ~Most people now just use 2 large 12 volt batteries in place of the original 4-6 volters.. The L/H battery [or batteries if 6 volters are used] hooks the most negative post to the starter�s solenoid post & positive post to the other battery [or batteries ].. The R/H battery [or batteries] hooks the most positive post to the stud on the side of the starter & the negative post to the other battery(s).. You also need a ground wire hooked from chassis [battery box] ground to the cable connecting the two center batteries together.. ~If you send me your E-Mail address I will send you a wire diagram showing the proper battery hook up & wiring.. Let me know if you are going to use 2- 12 volt batteries or 4- 6 volt batteries & I will send you a proper wire schematic showing the proper battery hook-up for the battery application you are going to use.. In this case a picture is worth a 1,000 words.. ~On the power steering fluid?� Probably the best fluid is a special [read expensive] 2-cylinder P/S fluid that Deere sells especially for the old 2-cylinder tractors.. In a pinch you can use Deere Hy-Guard but you really should use the correct Deere P/S fluid.. [email protected]
