D sleeves
Austin
05-20-2004 06:53:14
I have a person who will do the boring and sleeving on my John Deere D but the company he was getting sleeves from is no longer making sleeves that big. Could anyone tell me where I could get sleeves to bring it back to 6 3/4. That way I can reuse the High altitude pistons I have.
Thanks!
JC
05-23-2004 07:29:43
 Re: D sleeves in reply to Austin , 05-20-2004 06:53:14
Austin,
I had a "D" sleeved in Canada recently. The shop in Montreal was able to get sleeves - very expensive up here.
A note of caution - I am not a "D" expert. I got several differing opinions on the following; it seems that the oil ring on the "D" travels to the very bottom [back] of the cylinder bore. The common sleeving procedure is to leave a step at the bottom of the bore to secure the sleeve. I was told that if you do this on a "D", the oil ring will drop into the step and snap off. Some machine shops leave the sleeve 1/2" longer to prevent this. About .050" of the JD oil protruded past the end of the bore into open space - I couldn't believe what I was seeing. Several people said that this is normal. I don't doubt their word because they are much more experienced than me, it just seemed very weird to me. Deere lengthened the original stroke by 1/4", presumebly to raise horsepower. I'm sure they ran engines for 1000's of hours with the oil rings partially exiting the bore with no problems! I just had difficulty with the concept. I had a custom oil ring made that didn't have a scraping land at the back side of the ring - very anal I know!
E-mail if you would like to discuss further.
JC
charles
05-21-2004 19:38:52
Hey Austin i have two std LPG aluminum pistons in good cond. 6.72 i think. high comp.
Earl S.
05-20-2004 08:40:46
Hi Austin, Los Angeles Sleeve Co. 1-800 822-6005 They have the sleeves they can supply up to 8.250 x 13. Earl In Illinois
Clooney
05-20-2004 08:37:21
Austin, I haven't bought any "D" cylinder sleeves for a while now but Kevin at -Farm Power Restoration- used to carry them.. Try Kevin at [610-845-3668]..
[email protected]
