1950 A oil filter seal
Nate in IA.
05-19-2004 20:58:49
Just started up this tractor after a rebuild. Ran for a few minutes and noticed the seal for the filter blew out. Could this be caused by high oil pressure? Positive I put the seal and filter in right. the oil pressure all most pegged one of those JD low,med. high gauge.
Clooney
05-20-2004 03:07:49
 Re: 1950 A oil filter seal in reply to Nate in IA., 05-19-2004 20:58:49
Nate, you ask...
Quote: "Ran for a few minutes and noticed the seal for the filter blew out. Could this be caused by high oil pressure?">>>
_Possibly, extremely high oil pressure could put a strain on that filter cover "O" ring.. But more than likely you still have an old �O� ring in the filter cover sealing groove.. Old �O� rings in that groove are a very common find & those old �O� rings get as hard as steel so they look & act like part of the casting..
~Use a heated wire, dental pick, or even a common awl & hammer & probe around in that �O� ring groove for signs of an old �O� ring I�ll bet you find one left in that groove..
CAUTON: DON�T over tighten the filter cover as there is great risk of bending the top of the filter container & that means an oil leak at the filter body & future low oil pressure & lots of extra work..
[email protected]
