Charging R
Woody
05-19-2004 19:48:15
Where is a good place to buy a 6 volt positive ground regulator I have got 2 from a local gen shop and they work for a little bit and then stop working. but the gen is still working if I ground the field. I did have a old regulator from a John Deere "B" I put that
on and it works just fine. Soon I will need to replace the one on the "B". Thanks CjW
Bob M
05-20-2004 08:07:59
 Re: Charging R in reply to Woody, 05-19-2004 19:48:15
Woody - About all I can figure is your new regulators cannot tolerate the shock/vibration being mounted atop the generator on an R � which is not exactly a vibration-free place on an R!
A buddy of mine has a pair of R�s - he struggles with the same problem. And I�ve experienced similar problems with imported aftermarket 6 volt regulators (purchased at TISCO) failing on my Farmall and MM. Apparently the new regulators are less robustly constructed than the OEM Delco units originally supplied. After a season or two something happens - an internal solder joint breaks or a resistor goes open - and the new regulators quit working.
A couple suggestions: 1 � Try to find a Delco regulator � not an imported knockoff. 2 � Mount the regulator someplace else on the tractor where there�s less vibration (is there such a place on an R?!!).
Another possibility: Ground the generator field thru a 4 ohm or so series resistor. Retain the regulator to serve as a cutout only. The generator will now �run wild� but the series resistor will limit charging current to 2 - 4 amps. Will be sufficient to keep the battery up so long as you do not use the lights, but not enough current to cause the battery to overcharge and "boil".
Woody
05-20-2004 08:24:15
 Re: Re: Charging R in reply to Bob M, 05-20-2004 08:07:59
Thanks Bob
