Benjamin, you say you have no spark despite all those new ignition components and ask for suggestions, so I will povide you with a systematic Coil Ignition Troubleshooting Procedure which should isolate where the problem lies with the use of only a simple test lamp or a volt meter, but it necessarily must be a little long. When you say you have no spark, have you removed the plugs but have their wires attached and their sides up against the tractor and turned the Ignition ON and cranked her over??? BOTH should yield a good visible blue spark as the engine is cranked. PRELIMINARY 1: Are you sure the points are gapped correct and opening and closing as the engine cranks and the distributor shaft turns??? Are you sure the points/condensor wires or wiring to the distributor from the coil is good, continuous, and NOT shorted out??? When you turn the ign switch on, there MUST be battery voltage present on the coils high (from switch, NOT to distributor) terminal if its a Delco distributor or power to the input terminal if its another distributor like a Wico. PRELIMINARY 2: When you say theres no spark, do you mean none at the plugs??? To eliminate any cap or rotor or plug wire problems which may cause no spark at the plugs, remove the coil wire from the distributor (leaving coil end inside coil) and place its end to within 1/8 inch away from tractor steel, turn the Ignition ON and crank her over. If a spark jumps from the coil wire end to trator steel but NOT at the plugs, you could have a cap or rotor or plug wire or plug problem. However, if she dont even spark there, see the Troubleshooting Procedure below. ***********TROUBLESHOOTING********************
1) For it to ever work, when you turn the Ign switch to ON, there must be hot battery voltage present on the coils high (from switch, NOT to distributor) terminal. Take a test lamp to the coils high (from switch, NOT to distributor) side, turn the switch on, and see if battery voltage is present????? ??? MUST BE TO EVER WORK If not, the switch may be bad (Ive seen that happen),,,,, ,,,,, or the circuit which feeds the switch (to its BAT input terminal) isnt hot with battery supply voltage,,,,, ,,,,, or the wires bad/open from the switches IGN output down to the coils high input side. A test lamp on the switches BAT input terminal will show if it has supply voltage present, and if so but not out its IGN terminal when turned on, the switch is bad. If it has no supply voltage on its BAT input terminal, then the circuit/wire from the load (NOT to battery) side of the ammeter or up from the LOAD terminal on the Voltage Regulator is bad or open. SWITCH HAS TO HAVE POWER AND PASS IT TO THE COIL VIA THE IGN OUTPUT WHEN ON. NOTE: I dont think you have any series Ballast Resistor in the circuit/wire from the Ignition switches IGN output down to the Coil, but if so, it has to be continuous, NOT open, and around 1.2 to 1.85 ohms or so. If it has one and its bad/open she cant fire cuz youre NOT getting voltage down to the Coils high input terminal (see below). If it has one you should have a 6 volt coil and if not, a 12 volt coil. Regardless if it has one or not, she cant spark till you get voltage to the Coils high input side, so see below for that but if it does have one (that below still applies) it has to be good, NOT open, and continuous. If the switch is bad or it has no power to it, simply hot wire around the switch by running a temporary hot wire to the coils high (NOT to distributor) terminal and see if she fires then?? If by hot wiring the coils high input side she fires then, its either a bad switch or a bad wire from the switch to the coil or theres no power on the switches BAT input. 2) Once you get voltage on the coils high side (fix switch or switch feed or hot wire it) if she still dont fire as the engine is turned (assuming the distributor shaft turns and points open n close) place the test lamp over on the coils other low (to distributor) side and crank the engine over. The lamp MUST flash on and off as (during slow cranking) the distributor turns and the points open (lite on) and close (lite off). a) If the lite on the coils low side to distributor terminal never comes on, the coils primary is open,,,,, or theres a short in the condensor or point wiring,,,,, or the condenors bad/shorted,,,,, , or the points never open. Check for any wiring shorts and if the points open and close ??? Use an ohm meter to verify the coils primary has continuity and resistance around 2 to 3 ohms????? Try removing the condensor (in case its shorted) and if she fires then, you had a bad shorted condensor. b) If the lite never goes off, the points arent closing tight or are burned or pitted or badly carboned or theres an open in the wiring from coils low side to the distributor or in the points. The points closing shorts that circuit to ground so the coil can conduct current, so if the lite never goes off there, the points arent supplying a good ground connection or the distributor or wiring has no ground. 3) The primary ignition circuit is from the ammeters load side or the LOAD terminal on a 4 wire VR,,,,, ,,,,to the BAT input terminal on the switch,,,,, ,,out the switches IGN terminal (when ON),,,,, ,,,,, to the coils high supply side,,,,, ,,,,,out the coils low side,,,,, ,,to and through the points (when closed) to ground. Therefore, a test lamp at each point will show when and where the circuit is broken and if you have a bad switch,,,,, or no feed to the switch,,,,, ,,or an open/bad coil,,,,, ,, or points that arent closing (or carboned up) and opening,,,,, ,,or if the condensor may be shorted (remove it see if she fires then). Assuming your coil wire is good and your coil has continuity between its lil + and - terminals, the problem is often the switch is bad, or theres no power to the switch (maybe bad wire), or an open wire from switch to coil, and then the points are not gapped or burned badly or the condensor or point wiring may be shorted. THIS ASSUMES YOURE WIRED CORRECT, YOU HAVE POWER TO THE COILS INPUT WHEN IGN IS ON, HAVE A GOOD WIRE FROM THE COILS LOW SIDE TO THE DISTRIBUTOR, THE POINTS OR CONDENSOR WIRING ISNT SHORTED????? SUMMARY: Check for voltage on Ignition switches BAT input,,,,, ,Voltage on switches IGN output when ON,,,,, ,Voltage to Coil when IGN is ON,,,,, ,,Points gapped correct and open n close as distributor shaft turns,,,,, ,,,,, ,Test lamp on coils low side (and/or distributor terminal) flashes On and Off as points open n close,,,,, ,,,and youre wired correct????? ? You might also wanna insure the distributors terminal (gets wire from coil) IS NOT SHORTED OUT where it passes through the distributors side. If so, the light test on coils low side (as engine cranked over) would never come on as its always a short there. Insure wirings right and post back or e mail me if you need a wirign diagram. Try these tests and post back or e mail me at [email protected] with any questions and your findings. I have two articles that were published in Green Magazine a long time back on coil ignition systems if you wanna read a lot more on the subject I could e mail you also. Let me know, Good Luck n God Bless ya John T Nordhoff in Indiana
