720Deere, I�m not sure if you can push that driver off with through bolts or not.. I don�t even try.. I just use my big cross bar puller with bolts in the puller holes & plenty of heat on the driver.. Those drivers come off with difficulty & if too much pressure is used without heat the threads can pull out of the driver. ~On the clutch problem, the snap in & out problem could be broken internal parts, worn drive pin or hole, broken or de-laminated disks, or any number of other internal problems.. About all you can do is remove the pulley & check for proper operation & condition of all the internal parts.. [maybe you will get lucky & just find a delaminated disk].. ~On the oil leak?.. That could be a overfull reduction cover, or thinned oil, or broken operating sleeve, or plugged drain back holes, or ???.. ~Have you checked for excess crankshaft end play? If the endplay gets excessive it could cause both of your above problems.. [email protected]
