JC, you ask.. Quote: Question #1 - I am wondering if running the gas-oil mixture will cause shoot/carbon build-up on the rings, valves, etc?>>> _Yes, running that mixture with no load on it can add soot & carbon on the plugs & valves.. It shouldn�t hurt anything if you work it for a while to burn that soot off..>>> Question #2 - Is it good to keep the temp lower for a while since everything is brand new or should I block the rad. and warm her up to 190 degrees? The shutters are not re-built yet.>>>
_It wouldn�t hurt to take it easy for a couple of hours of run time but it really should be put through a few full heating & cooling cycles then the head re-torqued, then put to work for a while.. Running too cold for too long isn�t good for proper ring break-in & you really don�t want to glaze those cylinders before the rings seat.. Question #3 - It does not idle very smoothly and it backfires once in a while. I have been told that this could be caused by a blocked passage in the carb, a leak at the head or around the carb, or low fuel level in the carb bowl. The gasoline is fresh. I completely disassembled the carb and had it "tanked" but I didn't test the passages in the carb body to make sure that they were all fully open. I set the mag point gap but I did not check the mag "advance" adjustment. I set up the mag timing using the timing mark on the flywheel. Your suggestions���������..>>> _It could be anything from a blocked carb passage to a vacuum leak, to a carboned up intake manifold, to partially fouled spark plugs, to a tight valve, to ???.. You really need to get a load on that tractor & work it a while then see if it idles better.. If pulling the choke partially back on helps the rough idle & backfiring then suspect a vacuum leak or partially blocked carb passage.. Does your idle needle give you good control & does turning it effect the idle? Make sure the idle screw is just off the idle stop spring at fast idle as that can really effect a smooth idle.. If you have any leakage at the manifold base [common on the D] it will backfire & pop like crazy.. Question #4 - This tractor will be run occasionally but not worked hard at all. I would like to try Kerosene fuel as well as gasoline, to have the experience of running it on other fuel types. I am using Champion W-20 spark plugs. Should I try a different brand of plug? Should I try a different temperature range plug. >>> _Those W-20�s should be plenty hot.. Try opening the plug gap to about .035� or even .040� if the mag will fire them at that gap.. That should help the idle somewhat.. Some people seem to have problems with the Champion plugs but I run them in a lot of my 2-cylinder tractors without any problems.. If you don�t like the Champion�s you could always try a set of Autolite 3077.. It might not hurt to try a new set of plugs anyhow if those W-20�s are carboned up that could be your backfire problem.. If you keep the engine temperature up around 190�-200� it should run good on kerosene just warm it on gasoline first then switch to the kerosene.. [email protected]
