BATTERY HOOKUP ON 720 DIESEL
Luke Erpelding
05-19-2004 14:30:21
SHOULD THE 6-VOLT STARTING MOTOR BATTERY BE NEG OR POSITIVE GROUND?
Clooney
05-19-2004 18:28:41
 Re: BATTERY HOOKUP ON 720 DIESEL in reply to Luke Erpelding, 05-19-2004 14:30:21
Luke, all those old 2-cylinder Deere's including the 6 volt diesel�s came as positive ground.. The 24 volt diesel was both a positive & negative ground & that would be the exception..
~If you change the ground or aren't sure what ground it was/is then you really need to polarize the generator before using that tractor.. To do that first install a FULLY charged battery [at the correct ground polarity], then just ground the generator's [F] post {smaller of the two} to the generator�s case,, then momentarily jump battery power from the regulator's [BAT] terminal [that's the one that's always hot] to the generator's [A] post {larger of the two},, you should get a spark & if so remove the jumper wire as it is polarized..
[email protected]
John T
05-19-2004 15:04:49
Luke, it came from the factory wired POSITIVE ground. If its reversed, it may be possible to get her to charge and the starter motor would still turn the same direction regardless, but theres those gauges, ammeter, coil polarities etc etc etc plus other issues to cause problems, so I would DEFINITELY connect her POSITIVE ground as original.
Post back or e mail [email protected] any questions.
Good Luck n God Bless
John T
