Gasoline in crankcase oil on JD 620
Rick
05-19-2004 12:55:09
Recently changed engine oil on my JD 620. After approximately 4 hours of work I checked oil and its thin and smells like gasoline. I have only owned the tractor 6 months and the previous owner replaced the sediment bowl/low oil pressure unit. What else could be causing this ??? Any help would be appreciated. Rick
Bob in Illinois
05-19-2004 18:04:03
 Re: Gasoline in crankcase oil on JD 620 in reply to Rick, 05-19-2004 12:55:09
Rick ,You should check the diaphram of the sed. bowl/ low pressure unit for pin holes. Even though it was just serviced it could be the source of your fuel in crank case. This problem can be caused by useing fuel with alcohol blend. The diaphram doesn't hold up if alcohol is present. Personal experience... a 620 with a crankcase full of fuel sitting a few months and a 630 , same problem with fuel draining back into crankcase through a perforated diaphram. This one cost me an overhaul because I didn't check the oil before starting and seized it tight.
