'36 B Oil Filter
Mark
05-19-2004 07:32:19
I have a '36 B. I ordered an oil filter and and drained the oil. The filter I got was similar looking to modern ones and appears to be right for a later B, with flat ends, rubber seals etc. However all my tractor had was a metal Purolator canister with a 1/2" top pipe, a hole in the bottom and nothing inside for an element. I don't have a repair manual that covers my early B, what gives? I assume there may be some sort of replaceable element material that should be in that cannister?
Mark
old
05-19-2004 10:21:54
 Re: '36 B Oil Filter in reply to Mark, 05-19-2004 07:32:19
I have a 35 B and the owners manaul says to wash the filter in gas and then air dry it and put it back in. I've done it that way for years and I know thats how my grandfather did it back in the 40s.
Mike M
05-19-2004 10:13:09
It sounds like you have the original reusable cleanable type filter.You can change it over to accept the disposable type if you want to.
Johan
05-19-2004 10:07:29
If there is a brass Purolator filter that is not broken or miss shaped in any way, you could steam clean it and put it back in.
BMAN
05-19-2004 08:34:07
You need to order the oil filter outlet assembly from John Deere. Part # AA2096R.
Rod M1
05-20-2004 09:25:43
 Re: Re: '36 B Oil Filter in reply to BMAN, 05-19-2004 08:34:07
The assembly will cost about $20
