4320 Lights
Gunner
05-19-2004 05:35:27
I am looking for a little help with 4320 lights. The lights were jury rigged when I bought the tractor a couple years ago. I am redoing the lights back to original and have replaced all the lights, the harness under the platform to the fenders, the wiring in the fenders to the lights, and the switch. My problem is I have no lights to the rear. I am only getting about 2-3 volts out of the switch going to the lights in the rear. I am getting battery voltage to the headlights and they work on both High and Low beam. Any advice or a schematic would be appreciated.
Thanks
Gunner
chris
05-19-2004 20:48:41
 Re: 4320 Lights in reply to Gunner, 05-19-2004 05:35:27
Does your switch have another position for lights? I think with the lights on either Hi/Lo beam there will be lower voltage so the lights to the rear don't blind people following. I'm thinking you should try the first position of the light switch and check your voltage. Some rear lights had a second bulb that made the rear light red. chris
Gunner
05-20-2004 03:23:15
 Re: Re: 4320 Lights in reply to chris, 05-19-2004 20:48:41
Pos 1 should be flashers only and I only have about 2-3 volts from switch to flasher unit. Pos 2 and 3 one should have red light to rear and the other white to the rear and both pos only have the 2-3 volts. I am wondering if the switch input for the rear lights comes in on a different feed and if so where does it draw power from.
Thanks
Gunner
