1971 John Deere 140 H3 Mule Drive Installation
Fred
05-18-2004 10:34:51
Hey all...
My FIRST Deere, and FIRST mow of my 4 acres. And I'm completely clueless. I removed the blower with no problem. Installed the deck with no problem. Then I turned and saw the mule drive. Hmmmm. Ok, so I see "where" it goes, just don't know "how" it goes. The way I have it sitting now the "arms" are facing forwards and out of the front of the tractor. Doesn't make sense to me. I tried to spin it around, and put the "arms" under the tractor. The pivots didn't seem to line up.
HELP! I'm hoping to get my steed mowing this evening.
THANKS!!!
Fred
Bob
05-18-2004 10:41:20
 Re: 1971 John Deere 140 H3 Mule Drive Installation in reply to Fred, 05-18-2004 10:34:51
The mule drive hooks up under the front of the tractor, where it's four pins hook in 4 slots. The arms with the clevises on them extend under the tractor, and attach to the lower front of the mower, one on either side of the anti-scalp roller.
Fred
05-18-2004 10:45:14
 Re: Re: 1971 John Deere 140 H3 Mule Drive Installa in reply to Bob, 05-18-2004 10:41:20
Thanks a TON! I'll look into that when I get home from work. It makes sense. When I tried to mount the mule up under there, I just couldn't get it to seat into the 4 slots. My frustration level was high, however, at that point with "other" problems at the homestead.
Thanks for your help Bob, especially so fast!
Fred
Bob
05-18-2004 11:08:40
 Re: Re: Re: 1971 John Deere 140 H3 Mule Drive Inst in reply to Fred, 05-18-2004 10:45:14
Connect the straps from the mower to the mounts under the tractor, leaving the little lift straps unhooked for the moment.
Hook the "mule" under the front end of the tractor with the arms from the "mule" lined up with the front of the mower, then lift the front of the mower (a helper is good at this point!), and connect the arms from the "mule" to the front of the mower deck.
After the "mule" falls off the tractor about 37 times during this procedure, you'll get the hang of it!
Then, with the tension knob on the front of the mule backed off, install the belt over the clutch pulley, and over the "mule" idlers, and roll it over the deck pulley. Then, connect the lift straps, start the engine, and raise the mower deck. DO NO ENGAGE THE CLUTCH YET!
Shut the engine OFF.
Turn the tension knob on the front of the "mule" until the pointer gets up to "initial belt tension". Roll the mower drive over by hand a few turns, making sure the belt has no extra twist by the "mule" pulleys, and that the pointer still indicates correct tightness. (There is a brake on the electric clutch that will resist you turning it over by hand, but usually it is possible!)
Get everyone and everything out of the way and start the engine, keeping the speed a little above idle, and engage the electric clutch. If you have installed the belt correctely, with no extra twists, the drive should run smoothly. Shut down the engine, and again verify belt tension according to the pointer on the "mule". If OK, you should be set to mow.
Fred
05-19-2004 06:49:14
 Re: Re: Re: Re: 1971 John Deere 140 H3 Mule Drive in reply to Bob, 05-18-2004 11:08:40
Thanks again Bob. Got it hooked up last night thanks to you. And yes, the mule dropped at least 5-10 times. Took a swipe the lawn and noticed that the center blade is higher than the two flank blades. Took the deck back out from under the tractor, and tipped it up. Yup, the center blade straight and sits higher.
Is there an adjustment? I really need to get a manual for the deck, as well as the blower.
Thanks again!
Fred
Bob
05-19-2004 09:02:32
 Re: Re: Re: Re: Re: 1971 John Deere 140 H3 Mule Dr in reply to Fred, 05-19-2004 06:49:14
The deck may be deformed where the spindle bearing assembly mounts due to someone having whacked a rock or other debris with the blade.
What I do is invert the deck and shim it up with blocks until it's level side to side and front to back, and then I use a little magnetic level on the blade hubs to verify that all three spindles are level with the deck, and each other.
If one is off, you can install a flat washer between one ear of the spindle bearing and the deck to "cock" the bearing so the blade again runs level with the deck. The deck is relatively easy to bend with a little hammering of the metal around the spindle bearing, to restore things to original, also, if you don't want to mess with the washers.
Put the blades on, and verify that the tips line up where the blades pass close to each other.
A little work on the deck, as I've described, to line everything up makes for a very nice, even cut.
That is until someone whacks something with the mower again. AAARRGGGHHHH!
