How tough is PTO on 52 Model B?
Bob Weber
05-18-2004 06:24:37
I was wondering how much of a load I can put on the PTO of my 1952 Model "B"? I run a 5-foot brush hog with it, and at times in tall, heavy grass it will really make the tractor grunt. The reason I ask is that when I got the tractor the PTO gears and bushings were all beat up and worn very badly. I have since replaced all of that, but would like to know if I can really put a heavy load on that PTO, as it just didn't look like that little 3 3/4 inch bevel gear setup in the bottom of the transmission was built to take much power. Thanks!
ChuckW
05-18-2004 11:25:31
 Re: How tough is PTO on 52 Model B? in reply to Bob Weber, 05-18-2004 06:24:37
I think the jerking motion of low rpm on the engine and power surge is the hardest thing to use with the bushog. I always kept engine to highest RPM to prevent the governor surge as Clooney describes. With a slip clutch you shouldn't have trouble with blade impacts, however I have found a good open discharging mower is the best in high grasss. Food for thought is that when Deere made these tractors....bushog????? ?????
Clooney
05-18-2004 09:03:44
Bob, the early B's had horsepower limitations but Deere beefed the later ones up enough to handle full engine power.. Probably because many farmers didn't pay any attention to the early limitations..
~You shouldn't have any problems with a 5' brush hog on a late "B".. I have been using a 5' foot hog on a late "B" for years without any problems.. I can stall the tractor if the ground speed is too fast & the weeds are too thick, or break a shear pin in the gear box drive but as of yet haven�t damaged the PTO or gears.
~Keep the RPM�s up so the load is smooth & keep a good functioning shear pin or well lubricated slip clutch between the hog & the tractor & it shouldn�t be a problem..
~Running with no slip or shear protection & hitting something that instantly stops the blades can easily damage an internal tractor PTO shaft or PTO gear set..
~Make sure the hog follows the tractor correctly & watch the drive shaft angles.. If it starts hammering when turning corners you have something set up incorrectly.. That hammering can easily damage the internal PTO bearings, PTO shaft, or tear up the gears..
[email protected]
John T
05-18-2004 07:31:17
Bob, Sorry, I dont have any Horsepower or Torque ratings on that B PTO, but a problem Ive encountered is them shearing the key on one of the bevel gear shaft which obviously disables them. From my experience, I sure agree a 5 ft bush hog can be one *&^^%$$ of a load on a B if you brush hog instead of mow and get into thick wet heavy grass grrrrr rrrrowlllll lllll llll. I guess about all you can do is have the bush hogs blades good n sharp and use first gear in the heavy stuff, but not having live power makes it tougher. Any initial engagement if theres a heavy PTO load sure strains the gears.
Good Luck n God Bless
John T
Russ
05-18-2004 17:53:26
 Re: Re: How tough is PTO on 52 Model B? in reply to John T, 05-18-2004 07:31:17
DEERE HOG? I AGREE WITH ALL THE GUYS: DEFER OFTEN TO LOW GEAR, BLADES SHARP, KEEP ALL LUBED AREAS UP TO DATE, THROTTLE UP HIGH AND A SOCK FULL OF SHEAR PIN MATERIAL IF DEERE HOG ABUSE IS ON THE SCHEDULE. GOOD LUCK.
Mike M
05-18-2004 07:21:22
I have fixed several of these but have never ran them much afterwards. I think they may hold up better because of the redesigned bushings being two piece and redrilling the oil holes they may lube better.Did you do this procedure on yours ?
bob
05-18-2004 08:53:22
 Re: Re: How tough is PTO on 52 Model B? in reply to Mike M, 05-18-2004 07:21:22
Yes, I did drill the oiling holes, as the original bushing looked like it had gotten very hot due to the discoloration on it, so I wanted to make sure it got enough lube.
