1959 or 1960 435 john deere tractor
Sue
05-17-2004 19:33:36
Looking for any information on the 435 john deere tractors. I do know that they were diesels made by GM. My husband just bought one and I and I was just curious. Thanks
buickanddeere
05-18-2004 20:33:55
 Re: 1959 or 1960 435 john deere tractor in reply to Sue, 05-17-2004 19:33:36
J.R. Hobbs wrote about all there is to know abou the 435 in "30 series 2nd edition". The ring and pinion is fine as long as condensation or rain water doesn't get into the trans around the shifter boot. Somebody isn't horsing it, rocking/jerking back and forth while stuck etc. Or ballasting a 435 down to a 630's weight and hooking it to a 630's sized load. Then lugging it's engine to the last HP in 1st or 2nd gear for hours at a time. No rear wheel weights or liquid ballast should be added. If your hubby is rebuilding the engine there are several items to improve safety and cool weather starting. What ever he does, just don't grind the valves and seats plus install a set of rings.
Larry G
05-18-2004 11:51:30
I agree with Mike about a 435 being hard to start, however if you plug in the engine heater before hand they start well. I think mine is the greatest little tractor. I have used it for plowing, mowing, parading, etc. and it will do anything I ask of it EXCEPT quiet on the ear drums. I just love to hear it run and it has a lot more guts than my 430. Just wished it had power steering. My two cents.
MIKE HANLEY
05-18-2004 08:05:36
Two things come to mind when telling a new comer about the 435. One is they were somewhere inbetween hard to start,,,and impossible to start in the winter. If yoy need the tractor in cold weather to plow snow,,,,,keep it in a insalated heated shed. The other thing is not to "soup up the engine". The transmissiom and rear end on the 430 are the same as what what on the 420, 430 gas tractors which is the same as what was in the 40 tractors. ,,,,, ,SO add the extra strane of the increased HP of a 420 and the 430,,,,,AND NOW add a another 7 HP increrace of horsepower of the 435 over and above the 420 430 and you have maxed out the transmission and rear end. I am sure there is a puller out there that will say he pulls a souped up 435,,,,, well it's just a matter of time before the guys is looking for parts. But he wouldn't tell you that is it's still running. (I have better things to do with my money other then to go go out and push a 50 years piece of equipment to see if I can go just up to the point of totaly distroying it for 30 seconds of glory and braging rights at the bar. I respect old machinery two much to see it cobbled or distroyed.) Basicly the 435 is the 430 with the GM engine built for the AG world. They also had a 440 built for the industral world in both a wheel tractor and a crawler tractor that had the same engine in them as the 435 or the 430 gas engine.
MIKE HANLEY
05-18-2004 08:21:19
 Re: Re: 1959 or 1960 435 john deere tractor in reply to MIKE HANLEY, 05-18-2004 08:05:36
Side note here not really related to the 435 but for the 440 industral,,,,in later years JD changed the carb and made some modifacations to the 430 gas engine and raised the engine RPM's in an efford to have the gas engine up to the same HP as the GM Diesels and then retested the 440 at NEB Offical tests, but never did these modifacations to the gas engines of the 430 AG tractors. Just reviving up the PRM"s on the 430 AG engine woul;d have throwen off the 540 PRM"s of the PTO to meet the AG enginerees standard rating. The industrals tractors did not have to meet the AG specs.
