live hydraulics on JD A
Ken
05-17-2004 18:40:28
I bought a live hydraulics/power steering unit for an A. I believe I need to remove one of the original hydraulic pump gears? And run a line to the lower rear hydraulic section of tractor for oil supply. Anyone with some knowledge on this? Help greatly appreciated.
Greg F
05-18-2004 05:37:46
 Re: live hydraulics on JD A in reply to Ken, 05-17-2004 18:40:28
Where could I purchase this live hydraulics kit?? What advantage does it give me?? Clooney I would also like a copy of the instructions. I will email you from home tonight. Thanks
Clooney
05-18-2004 03:22:38
Ken, you didn�t give a year of your �A�? If an early �A� you need to try that pump on the governor.. On some of the early A�s there is an interference of those live pumps to the governor housing..
~Now on mounting the pump & lines.. If you have an early tractor with power-lift you will have to drill the drain hole out & tap to � pipe.. The power-trol or power-lift housing will have to come off & a spacer plate [using two gaskets] added between the P/T valve housing & rear tractor housing.. The original P/T pump will have to come apart & the idler gear removed then the pump halves re-sealed to prevent leaks..
~Your spark plug wires might also be too short & depending on the tractor year the crankcase vent modified..
~I have a set of installation instructions [somewhere, I�ll have to look for them].. Send me your E-Mail address & I will try to find them for you..
[email protected]
