530 PTO growl
STex ted
05-17-2004 15:43:22
With PTO selector engaged I hear a bearing growl sound inside transmission. No sound if selector disengaged. Makes no difference if PTO clutch engaged or not, nor if heavy PTO load, light load or no load. PTO works but I'm concerned about possible damage to transmission/PTO driveline. Is there a bearing on the "selector shaft" accessible from first reduction gear cover?
Clooney
05-17-2004 17:40:03
 Re: 530 PTO growl in reply to STex ted, 05-17-2004 15:43:22
third party image
STex ted, unfortunately those 530's use bushings for the front PTO bevel gears.. When they wear the PTO starts to get growly.. It could also have that thrust washer worn out that Chuck spoke of..
~As Chuck mentioned those PTO bevel gears are about the last thing to come out of the bottom of the transmission..
~You can pull the trans shifter cover & work around down in under the trans gears & feel for loose bevel gears in the bushings.
~See picture for red arrows indicating the bushings & thrust washer, or bearing that could be possibly your problem..
[email protected]
ChuckW
05-17-2004 16:36:27
there is a bearing at the imput shaft gear, that is driven off the main gear. Also there is a thrust washer at the front of the output shaft. I have a 530 that made a similar noise and the thrust washer had been broken/missing. This allowed the shaft to move rearward out of complete mesh with the driven gear. This may not be your problem is a *$4* of a job to replace. You'd have to remove the transmission gears to get to it. Replacing the imput bearing is also no easy job. This requires a teardown anyway you go. I might recommend to check your fluid levels and quality. I use 140 oil in my transmissions. Wish I had a quick fix but diagnosis will take some inspections.
