1010 oil pump tool?
Bret
05-17-2004 12:26:49
I'm putting my 1010 gas engine back together. I went to put the oil pump back on and the shop manual says the pump has an offset gear and that I need a special tool to "time" the pump. For the life of me, I can't see any offset on the gear, but JD says it's there. Do I need the special tool? My local dealer probably has one.
Henry J
05-18-2004 05:44:38
 Re: 1010 oil pump tool? in reply to Bret, 05-17-2004 12:26:49
Brett
I havn't done that engine but it sounds like one I have done in the past.
Like said before you can drop the pump in any way, but if you then have to rotate the distributor a bunch you will get the wire hook ups in really odd and unhandy locations.
Here is another way that I think works if you have the engine on a stand it is easy. Get it on no 1 tdc on the firing stroke. Take one hand and insert the oil pump and drop the distributor in and rotate it to see where the points just start to open when the rotor is pointed to where you want the no 1 plug wire to be.
Then you can pull the pump down gently just until the gears clear and insert a large screwdriver in the dist slot and rotate it a tooth (or how many you want) reinsert the pump and drop the distributor in and see it you have it where you want it.
Good Hunting
Hunter n NOLa
05-18-2004 03:40:38
Also beware, the IT manual is wrong. At least the one I had was wrong. It showed the slot at about 45 degrees upward to the right (front of the tractor). The correct position is about 45 degrees upward to the LEFT (toward the rear of the tractor). Took me a long time to figure this out.
Another thought: while you have the oil pump out check the curled pin that positions the cam gear to the oil pump shaft. Best to replace it. I had one shear and messed up a engine for lack of lubrication. On further inspection found that someone in the past had used something like a nail instead of the curled pin. I ended up having to replace the engine.
Bob
05-17-2004 16:39:32
The slot in the top of the oil pump is offset so the distributor will only drop in one way, thus assuring correct timing if someone removes the distributor for service and replaces it.
It is the position of this slot relative to the block when the engine is on #1 TDC that you are setting, and the fact that the oil pump gear is helical causes the shaft to rotate as you insert the oil pump up from the bottom, making this a somewhat difficult job.
If you have a book with a drawing that shows the correct position of the slot, looking down the distributor hole, you can do it without the tool.
Get it as close as you can by guess, insert the oil pump, and check the position of the slot against the drawing. If you are off, pull the oil pump, and insert it a tooth or two farther in the direction it needs to be, and try again. After a couple of tries, you should have the slot oriented where it's supposed to be.
Actually, other than to have the distributor in the standard factory configuration, it makes no difference where the oil pump slot is because you can attach the wires to the distributor cap in a orientation other than factory to conform to the non-standard oil pump slot position, and fine-tune the timing by rotating the distributor.
The only problem with this is that in the future it may confuse someone doing a tuneup!
Bret
05-20-2004 04:50:00
 Re: Re: 1010 oil pump tool? in reply to Bob, 05-17-2004 16:39:32
Thanks guys. Got it by pointing the distruibutor rotor at #1 cylinder position and trial and error. Should by within a few degrees of where I want it.
